high precision system time
deadlyboy
Post by deadlyboy »
hi every body
for creating a real time system i need to have system time which has microsecond precision.
i used halGetCounterValue() and halGetCounterFrequency(). but it will reset every 25 second.
my code is lke this :
uint32_t tnow = getSystemTimeInMicroSecond();
while(true)
   if(getSystemTimeInMicroSecond() - tnow => 13333)
   {       tnow = getSystemTimeInMicroSecond();
      dojobOne();
   if(getSystemTimeInMicroSecond() - tnow  >= 25555)
      dojobTwo();
so i cannot use chThdSleepMicrosecond().
chTimeNow() gives me a 1 millisecond precision.if i had a counter which counts every 168 ticks of micro (stm32f4-168mhz) i will have a system time in micro second.
is it possible to implement this ?? if yes how ??
Re: high precision system time
ChibiOS/RT 3.0 supports high resolution time in the kernel, you can have system tick with 1uS resolution.
You may also consider the GPT driver but only for delays.
