ChibiOS on the Arduino Uno
Moderator: tfAteba
mikenick42
Post by mikenick42 »
I was just wondering if everyone here is using the libraries greiman wrote for the AVR chips with small amounts of memory. I tried to modify the RT-ARDUINOMEGA example and even with no OS features enabled couldn't get a program to fit into the flash.
The NIL-ARDUINOMEGA example was easy enough to modify and NIL is working for me thus far, so this is more a question of curiosity than looking for help.
devlware
Re: ChibiOS on the Arduino Uno
Post by devlware »
I also modified the same MEGA example to run with the Arduino Uno but no luck.
I did not understand why the compiler reports so huge numbers for both program and data as follows.
Size after:
AVR Memory Usage
Device: atmega328p
Program: 31668 bytes (96.6% Full)
(.text + .data + .bootloader)
Data: 3973 bytes (194.0% Full)
(.data + .bss + .noinit)
-------- end --------
Regards, Diego
utzig
Been thanked: 20 times
Post by utzig »
Here's the output of the current Arduino Mega 1280 demo as is:
AVR Memory Usage
Device: atmega1280
Program:   28226 bytes (21.5% Full)
Data:       3951 bytes (48.2% Full)
Now if I disable the TestThread:
AVR Memory Usage
Device: atmega1280
Program:   11652 bytes (8.9% Full)
Data:        466 bytes (5.7% Full)
Hope that helps to make it clear what's happening! ;-)
Cheers,
Fabio Utzig
devlware
Post by devlware »
:oops:
Size after:
AVR Memory Usage
Device: atmega328p
Program: 13474 bytes (41.1% Full)
Data: 480 bytes (23.4% Full)
Now its working.
utzig
Post by utzig »
It's all good! I'll wait for your patches so I can add official support again! :P
Cheers,
Fabio Utzig
mikenick42
deviware? Did you ever make any progress on a patch?
