**KS0108 driver
JoVM
**KS0108 driver
Post by JoVM »
I have a Gph LCD laying around based on the KS0108 controller. Is there a driver guide for chibiOS 3.0.0?
Re: **KS0108 driver
You should look at the uGFX project.
JoVM
Re: **KS0108 driver
Post by JoVM »
Giovanni Tnx! I think I would prefer uGFX over Qt.
Re: **KS0108 driver
Sadly uGFX does not yet have a KS0108 driver but there is everything else you need to use your display (including a very detailed tutorial how to set up a project using ChibiOS/RT, uGFX and ChibiStudio).
It is fairly easy to add a new driver (for your KS0108) as the interface is well documented and there are already a lot of existing examples including several for monochrome graphic displays.
We are happy to help you where we can should you have any questions.
