Operation palReadPad ()
ChibiOS public support forum for topics related to the STMicroelectronics SPC56x family of automotive micro-controllers.
GianlucaLaManna
Post by GianlucaLaManna »
Hello.
This is my code:
static WORKING_AREA(waThread1, 128);
  (void)arg;
  chRegSetThreadName("detection");
  int count=0;
  while (TRUE) {
   //  uint32_t duration, distanceCm;
          palClearPad(PORT_A, TRIG_PIN); // low
          osalThreadSleepMicroseconds(2);
          palSetPad(PORT_A, TRIG_PIN); //high
          osalThreadSleepMicroseconds(10);
          osalThreadSleepMilliseconds(2000);
          palSetPad(PORT_A, ECHO_PIN);
         // count++;
        chprintf((BaseSequentialStream *)&SD1,"Firts Count: %u\r\n", palReadPad(PORT_A,ECHO_PIN));
Why the function palReadPad return always 0?
I use an ultrasonic sensor HY-SRF05 and my echo pin is mapped with pinmap wizard on pin 84 (A2).
Gianluca.
Re: Operation palReadPad ()
It depends on the pin configuration, if the pin is not programmed as output, push-pull WITH read-back then it cannot be read. See the SIUL chapter in the reference manual.
