STM32_CECSW enforces HSI or LSE enabled even if not used
ulikoehler
Post by ulikoehler »
if I use a mcuconf.h similar to this (excerpt):
#define STM32_HSI_ENABLED                   FALSE
#define STM32_CECSW                         STM32_CECSW_HSI
ChibiOS 3.x (HAL: current SVN) prints this error:
#error "HSI not enabled, required by STM32_CECSW"
Neither do I use CEC nor does my STM32F030x support it at all. The only options for CECSW are STM32_CECSW_HSI and STM32_CECSW_LSE, therefore either HSI oder LSE would have to be enabled which might not be the case for a low-power application.
What is the recommended method of disabling CEC so neither of those clocks need to be active?
Ad hoc, I could think of using
#define STM32_CECSW                         0xFF //Neither STM32_CECSW_HSI nor STM32_CECSW_LSE
but I think it is not advisable to do that because it might get ORed into some register we don't want to modify.
Best regards, Uli
Re: STM32_CECSW enforces HSI or LSE enabled even if not used
Using those pseudo-constants is what I did in other ports (I used 0xFFFFFFFF), of course making sure it is never actually ORed to the register value.
I added a similar fix to the F0, marked as bug #628.
