Could be possible with git to declare fatfs and lwip as submodule.
And thus get proper patch queue against upstream ?
I have a few patch that I want to publish.
Bastien
FATFS and LWIP patch queue
Re: FATFS and LWIP patch queue
The main repository is subversion not git. Personally I prefer to use released code, I cannot do regression tests each time something is committed.
It is not about using releasing or upstream top code. It is about to have a patch queue in order to ease porting.
If I want to patch fatfs or lwip further I do not know that patch are applied and why.
Bastien
Bastien
I have just created the fatfs patch queue.
See https://github.com/bastien-roucaries/Ch ... tien/trunk
If you want to publish under github and does not need to change your script for mirroring because submodule are really separate beast from main (and even from subversion).
You could I think get my branch.
I plan to do the same with the lwip
Done with lwip and fatfs repo.
BTW author of lwip warn to use only git head for 1_4_1...
i can do a forward port if needed
BTW one of your fix was upstreaming as :
commit d6fbe2a5adffaf7d55db4ca8518ebba092078e7b
Author: sg <[email protected]>
Date: Tue Oct 28 22:28:50 2014 +0100
fixed bugs #41495 Possible threading issue in select() and #43278
event_callback() handle context switch when calling sys_sem_signal()
