Posix-GCC target gone in 3.0?
toxygen
Post by toxygen »
Hello Giovanni,
I would like to ask why was Posix-GCC target removed from 3.x releases?
Re: Posix-GCC target gone in 3.0?
Not removed, just not yet ported over, like several other things.
toxygen
Post by toxygen »
Fair enough :)
thanks for a quick answer
toxygen
Post by toxygen »
Bringing this topic back from the dead, is it ever planned to port it back to stable chibios?
Yes, at some point, it is not exactly high priority. You could attempt to port the 2.6.x code, there are not many differences. Use the Win32 port as example.
rus084
Post by rus084 »
Hi . i'm new on this forum , but know ChibiOS much time .
i'm student on electronix faculty .
last night i coded posix port for current svn version. it compiles and works .
posix.zip
(12.92 KiB) Downloaded 484 times
else i made posix-arm port for chibios 2.6.7
https://github.com/rus084/chibios-arm-simulator
Thanks for code, on which platform is the ARM simulator running? any Posix-like?
rus084
Post by rus084 »
i runned it on android smartphone in chroot with linux environment (linux deploy). it work's on linux arm machines .
if compile via android sdk , can run simulator as android native program .
