Posix-GCC target gone in 3.0?
Posted: Sat Oct 03, 2015 7:19 pm
by toxygen
Hello Giovanni,
I would like to ask why was Posix-GCC target removed from 3.x releases?
Re: Posix-GCC target gone in 3.0?
Posted: Sat Oct 03, 2015 9:33 pm
Not removed, just not yet ported over, like several other things.
Posted: Sat Oct 03, 2015 10:00 pm
by toxygen
Fair enough :)
thanks for a quick answer
Posted: Fri Jul 22, 2016 6:53 am
by toxygen
Bringing this topic back from the dead, is it ever planned to port it back to stable chibios?
Posted: Fri Jul 22, 2016 7:47 am
Yes, at some point, it is not exactly high priority. You could attempt to port the 2.6.x code, there are not many differences. Use the Win32 port as example.
Posted: Thu Aug 18, 2016 11:46 am
by rus084
Hi . i'm new on this forum , but know ChibiOS much time .
i'm student on electronix faculty .
last night i coded posix port for current svn version. it compiles and works .
posix.zip
(12.92 KiB) Downloaded 484 times
else i made posix-arm port for chibios 2.6.7
https://github.com/rus084/chibios-arm-simulator
Posted: Fri Aug 19, 2016 6:28 am
Thanks for code, on which platform is the ARM simulator running? any Posix-like?
Posted: Fri Aug 19, 2016 10:00 am
by rus084
i runned it on android smartphone in chroot with linux environment (linux deploy). it work's on linux arm machines .
if compile via android sdk , can run simulator as android native program .
