Serial Driver and CHN_INPUT_AVAILABLE
antoniolinux
Post by antoniolinux »
Hi to all, i connect with a wire PA9 and PA10, i want similate when arrived data on SD1,
when arrived daa on sd1 start a event
if i write this
static THD_WORKING_AREA(waRead5, 128);
static THD_FUNCTION(Thread5,arg) {
  (void)arg;
  chRegSetThreadName("th_Riempio_Buffer");
  event_listener_t Uart1Data;
  eventmask_t activeEvents;
  eventflags_t flags;
  chEvtRegisterMask((event_source_t *)chnGetEventSource(&SD1), &Uart1Data, EVENT_MASK(1));
  while (TRUE) {
    activeEvents=chEvtWaitAll(EVENT_MASK(1));
       flags =chEvtGetAndClearFlags(&Uart1Data);
 if (flags & CHN_INPUT_AVAILABLE)
              sdWrite(&SD2,"OK\r\n",4);
  return 0;
i see only when i reset the board and later i see the event but only just once
if i use this
 if (flags )
All work well but i don't have the control of SD1.
If i disconnect the wired, i see start for every time the event, the thread In WTOREVT state
I see this post viewtopic.php?f=16&t=1394
for me code but i don't know the problem,
bye
Re: Serial Driver and CHN_INPUT_AVAILABLE
I don't see any obvious problem with the code.
antoniolinux
i fix it, the code that i write is good but i set the pull UP the pin RX for use it
  palSetPadMode(GPIOA, 9, PAL_MODE_ALTERNATE(7)); //tx
  palSetPadMode(GPIOA, 10, PAL_MODE_ALTERNATE(7)); //rx
  palSetPadMode(GPIOA,10,PAL_MODE_INPUT_PULLUP);
thanks for all.
A.
