STM32F103 Working Only After Pressing Reset
kdsouza
Post by kdsouza »
Hello Everyone,
I am working on the 2.6 FATFS for F103R Example.
My Code Utilizes Serial 1,2 UART3, SPI2, ADC1 and a few GPIOs. Serial1 is a GPS Modem, Serial2 is the console output for debugging, UART3 is a WiFi modem.
Once I Erase the Chip and Flash My code it works fine ( ST-LINKV2).
Once the Board is powered on, one UART3 Peripheral doesn't work fine. It does 2 operations and then doesn't respond to anything.
Weird issue is, if i Connect the board to a Laptop ( UART2 TX RX and GND), the board works fine after Power off and Power of, but if i disconnect the Laptop, it doesn't work.
Now, If i power the board up, press the reset button, it works fine.
I've check all connections, regulator outputs, everything is in the fine range, no fluctuations, no interference what-so-ever.
Anyone has had this issue before? Where you need to Press the Reset Button after the board is powered on to get the code to work properly?
steved
Has thanked: 12 times
Been thanked: 138 times
Re: STM32F103 Working Only After Pressing Reset
Post by steved »
Could it relate to the rise time of your power supply? Can you (at least temporarily) add a switch so that your power supply is definitely at 3.3V before applying it to the processor?
Could be a missing ground/0V connection which the laptop might supply.
Bad joint on the components providing the power up reset circuit on your board.
Are you loading code/data in RAM using the debugger? it would not be there after a cold reset.
kdsouza
Post by kdsouza »
Thanks for the Tips,
SCB_AIRCR = (AIRCR_VECTKEY | (SCB_AIRCR & (0x700)) | (1 << 2)); // reset
I am doing this after checking if the microcontroller has been on for less than 1sec.
I know this is ugly and crude and what not, but i am in another country testing the setup. :cry: and if i don't get this working, i'l be fed to the lions for sure :D
JK,
Cheers
dismirlian
Been thanked: 16 times
Post by dismirlian »
How about the BOOTx pins? Are they at the right levels?
mobyfab
Has thanked: 21 times
Been thanked: 31 times
Post by mobyfab »
Do you have a capacitor on the reset pin?
This is needed to let the power stabilize before the mcu turns on.
