This is just a bug report with ChibiOS 3.
If spiSend is called with a zero size buffer, the dma transfer is configured, and stared, but will never issue an IRQ due to the zero size, and as such the thread will never unsuspend.
SPI API Bug
Re: SPI API Bug
The OS does not check parameters unless checks are enabled in chconf.h. The condition is actually tested:
Enabling debug options would have stopped execution.
void spiSend(SPIDriver *spip, size_t n, const void *txbuf) {
osalDbgCheck((spip != NULL) && (n > 0U) && (txbuf != NULL));
Re: SPI API Bug
Hrmm, ok, but personally I would have added a simple check for zero size, and return quietly if it is, just like all other IO type methods in most other APIs and languages, ie
fwrite(buffer, 0, 0, fp) == 0
Re: SPI API Bug
Our design pattern is that error checks are only performed at development time for efficiency/codesize reasons. The application is responsible for passing correct values to the API.
