[INFO] Watchdog driver added
It is based from the one contributed by z80 a while ago. It is very simple, use is trivial.
So far I tested it on an STM32F3 and it works. I need to update all other platforms.
DGW
Re: [INFO] Watchdog driver added
Post by DGW »
I use the driver for STM32F407. He began to work only when I comment out the line:
// while (wdgp-> wdg-> SR! = 0)
Thanks, will give a try during weekend.
Fixed by moving the loop before the assignments (according to the RM). Added a demo for the F4 too.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
Works fine on the F4; however just a little tip when debugging.
Make sure you set a breakpoint within chSysHalt(). Otherwise the watchdog resets the processor, and you can't see why you got to chSysHalt()......
It should also be possible to halt the WDG while debugging.
