"Chibistudio_hot" eclipse repository ?
Koen
Been thanked: 5 times
Post by Koen »
    the regular "Chibistudio" eclipse repository helper does not offer STM32F7 as an option but, as read on a post from august, a "Chibistudio_hot" repository might. The link [1] given is now 404, is there anothe fresh repository ?
    [1]: http://www.chibios.org/eclipse/chibistudio_hot/
Thank you !
Re: "Chibistudio_hot" eclipse repository ?
There is no hot version right now, the latest code is in ChibiStudio 15. You may update an old ChibiStudio from here: http://www.chibios.org/eclipse/chibistudio
Koen
Post by Koen »
Naming details obscure F7 and L0 options, from processors.xml :
    <processor class="board" target="STM32F7xx">
    <name>STM32F4xx Board Configuration</name>
    <path>resources/gencfg/processors/boards/stm32f7xx/templates</path>
    <default>resources/gencfg/xml/stm32f7board.xml</default>
    <basefilename>board</basefilename>
    </processor>
    <processor class="board" target="STM32L0xx">
    <name>STM32L1xx Board Configuration</name>
    <path>resources/gencfg/processors/boards/stm32l0xx/templates</path>
    <default>resources/gencfg/xml/stm32l0board.xml</default>
    </processor>
Thanks, I will fix and put it in the update site.
An update is available now that fixes also this issue.
Just do "Help->Check For Updates" in Eclipse.
