STM32F7 I2C
Koen
Been thanked: 5 times
STM32F7 I2C
Post by Koen »
    as anyone successfully used I2C with an STM32F7 ? I haven't found tests or demos of it and have tried to debug my try for hours now. Here's a condensed version of it :
    int main(void) {
       palSetPadMode(GPIOB, 8, PAL_MODE_ALTERNATE(4) | PAL_MODE_OUTPUT_OPENDRAIN);
       palSetPadMode(GPIOB, 9, PAL_MODE_ALTERNATE(4) | PAL_MODE_OUTPUT_OPENDRAIN);
       i2cInit();
       const I2CConfig i2cd1_cfg = {
          .timingr    = 0x40912732,
          .cr1       = 0,
          .cr2      = 0
       i2cStart(&I2CD1, &i2cd1_cfg);
       msg_t       i2c_result;
       i2cflags_t   i2c_errors;
       uint8_t    i2c_rxbuf[129],
                i2c_txbuf[129];
       memset(i2c_txbuf, 0, sizeof(i2c_txbuf));
       i2cAcquireBus(&I2CD1);
       i2c_result = i2cMasterTransmitTimeout(&I2CD1, 0x37, i2c_txbuf, sizeof(i2c_txbuf), i2c_rxbuf, sizeof(i2c_rxbuf), MS2ST(1000));
       if(i2c_result != MSG_OK)
          i2c_errors = i2cGetErrors(&I2CD1);
       (void) i2c_errors;
       i2cReleaseBus(&I2CD1);
       i2cStop(&I2CD1);
       while (true) {
          chThdSleepMilliseconds(500);
    Defines modified from defaults :
    #define HAL_USE_I2C            TRUE
    #define STM32_I2C_USE_I2C1 TRUE
    #define STM32_I2C_USE_DMA FALSE
    Results :
    i2c_result = -1 / MSG_RESET,
    i2c_errors = 0
    Is there anything obviously wrong ? I wrote the equivalent with STM32CubeHAL to make sure the hardware isn't at fault and it works.
Thank you,
Koen
Re: STM32F7 I2C
I haven't tested that driver on the F7 yet, there could be an error (likely in the registry if there is an error).
steved
Has thanked: 12 times
Been thanked: 138 times
Re: STM32F7 I2C
Post by steved »
I've successfully used the I2C on the F7 Disco in master mode (and, I think, in slave mode - can't remember for sure)
Some of my code is here
And I've just uploaded a specific example which worked for me
(Note that I was working with my modified driver which also handles slave mode, but I don't think I had to change any of the master-related code, except that there was a bug in the master code for transfers >255 bytes which is fixed in SVN)
F746_I2C_Master_Test.zip
F7 Disco I2C test
(51.22 KiB) Downloaded 396 times
Koen
Re: STM32F7 I2C
Post by Koen »
Well, sorry to have wasted your time. I2C does work. I had commented
#if (HAL_USE_PAL == TRUE) || defined(__DOXYGEN__)
  //palInit(&pal_default_config);
to reduce the test-case and concentrate on the two I2C pins only. I only discovered much later that palInit was also responsible for enabling the GPIO clocks.
