Using chnReadTimeout with TIME_IMMEDIATE for USB
midimon
Post by midimon »
Hi, Giovanni,
I am trying to use the latest ChibiOS from github.com to implement data transfer using USB as serial port. The code is as follows:
int main(void) {
  BaseChannel *pChn;
  size_t numBytes;
  uint8_t msg[8];
  sduObjectInit(&SDU1);
  sduStart(&SDU1, &serusbcfg);
  chThdSleepMilliseconds(1000);
  while (true) {
    pChn = serusbcfg.usbp->state == USB_ACTIVE ? (BaseChannel *)&SDU1 : NULL;
    if (pChn) {
      numBytes = chnReadTimeout(pChn, msg, 8, TIME_IMMEDIATE);
      chnWrite(pChn, (const uint8_t *)&numBytes, sizeof(numBytes));
The problem is that chnReadTimeout allways returns 0 when timeout = TIME_IMMEDIATE. It doesn't matter if I send data to USB serial port or not. If timeout != TIME_IMMEDIATE (for example timeout = 100) then chnReadTimeout returns number of bytes sent to USB serial port. Is this the expected behaviour of chnReadTimeout?
Re: Using chnReadTimeout with TIME_IMMEDIATE for USB
Are you using version 16.1.1?
Probably I saw the problem, could you try chnGetTimeout() as workaround?
midimon
Post by midimon »
Giovanni wrote:Are you using version 16.1.1?
I think yes. It is from the latest github.com master branch and it uses buffered queues.
Giovanni wrote:Probably I saw the problem, could you try chnGetTimeout() as workaround?
The following code works fine:
  while (true) {
    if (pChn) {
      while (chnGetTimeout(pChn, TIME_IMMEDIATE) != MSG_TIMEOUT) {
        numBytes++;
      numBytes = 0;
It returns the number of bytes send to the USB serial port.
I will post some modified code for you to try later, thanks for the report.
Just a note, it also affect the write operation in the same way.
The ticket page is here: https://sourceforge.net/p/chibios/bugs/695/
I committed on svn the following change to hal_buffers.c.
    ChibiOS - Copyright (C) 2006..2015 Giovanni Di Sirio
 * @file    hal_buffers.c
 * @brief   I/O Buffers code.
 * @addtogroup HAL_BUFFERS
 * @details Buffers Queues are used when there is the need to exchange
 *          fixed-length data buffers between ISRs and threads.
 *          On the ISR side data can be exchanged only using buffers,
 *          on the thread side data can be exchanged both using buffers and/or
 *          using an emulation of regular byte queues.
 *          There are several kind of buffers queues:<br>
 *          - <b>Input queue</b>, unidirectional queue where the writer is the
 *            ISR side and the reader is the thread side.
 *          - <b>Output queue</b>, unidirectional queue where the writer is the
 *          - <b>Full duplex queue</b>, bidirectional queue. Full duplex queues
 *            are implemented by pairing an input queue and an output queue
 *            together.
#include <string.h>
/* Driver local definitions.                                                 */
/* Driver exported variables.                                                */
/* Driver local variables and types.                                         */
/* Driver local functions.                                                   */
/* Driver exported functions.                                                */
 * @brief   Initializes an input buffers queue object.
 * @param[out] ibqp     pointer to the @p input_buffers_queue_t object
 * @param[in] bp        pointer to a memory area allocated for buffers
 * @param[in] size      buffers size
 * @param[in] n         number of buffers
 * @param[in] infy      callback called when a buffer is returned to the queue
 * @param[in] link      application defined pointer
 * @init
void ibqObjectInit(input_buffers_queue_t *ibqp, uint8_t *bp,
                   size_t size, size_t n,
                   bqnotify_t infy, void *link) {
  osalDbgCheck((ibqp != NULL) && (bp != NULL) && (size >= 2U));
  osalThreadQueueObjectInit(&ibqp->waiting);
  ibqp->bcounter = 0;
  ibqp->brdptr   = bp;
  ibqp->bwrptr   = bp;
  ibqp->btop     = bp + ((size + sizeof (size_t)) * n);
  ibqp->bsize    = size + sizeof (size_t);
  ibqp->bn       = n;
  ibqp->buffers  = bp;
  ibqp->ptr      = NULL;
  ibqp->top      = NULL;
  ibqp->notify   = infy;
  ibqp->link     = link;
 * @brief   Resets an input buffers queue.
 * @details All the data in the input buffers queue is erased and lost, any
 *          waiting thread is resumed with status @p MSG_RESET.
 * @note    A reset operation can be used by a low level driver in order to
 *          obtain immediate attention from the high level layers.
 * @param[in] ibqp      pointer to the @p input_buffers_queue_t object
 * @iclass
void ibqResetI(input_buffers_queue_t *ibqp) {
  osalDbgCheckClassI();
  ibqp->bcounter = 0;
  ibqp->brdptr   = ibqp->buffers;
  ibqp->bwrptr   = ibqp->buffers;
  ibqp->ptr      = NULL;
  ibqp->top      = NULL;
  osalThreadDequeueAllI(&ibqp->waiting, MSG_RESET);
 * @brief   Gets the next empty buffer from the queue.
 * @note    The function always returns the same buffer if called repeatedly.
 * @return              A pointer to the next buffer to be filled.
 * @retval NULL         if the queue is full.
 * @iclass
uint8_t *ibqGetEmptyBufferI(input_buffers_queue_t *ibqp) {
  if (ibqIsFullI(ibqp)) {
    return NULL;
  return ibqp->bwrptr + sizeof (size_t);
 * @brief   Posts a new filled buffer to the queue.
 * @param[in] size      used size of the buffer, cannot be zero
 * @iclass
void ibqPostFullBufferI(input_buffers_queue_t *ibqp, size_t size) {
  osalDbgCheck((size > 0U) && (size <= (ibqp->bsize - sizeof (size_t))));
  osalDbgAssert(!ibqIsFullI(ibqp), "buffers queue full");
  /* Writing size field in the buffer.*/
  *((size_t *)ibqp->bwrptr) = size;
  /* Posting the buffer in the queue.*/
  ibqp->bcounter++;
  ibqp->bwrptr += ibqp->bsize;
  if (ibqp->bwrptr >= ibqp->btop) {
  /* Waking up one waiting thread, if any.*/
  osalThreadDequeueNextI(&ibqp->waiting, MSG_OK);
 * @brief   Gets the next filled buffer from the queue.
 * @note    The function always acquires the same buffer if called repeatedly.
 * @post    After calling the function the fields @p ptr and @p top are set
 *          at beginning and end of the buffer data or @p NULL if the queue
 *          is empty.
 * @param[in] timeout   the number of ticks before the operation timeouts,
 *                      the following special values are allowed:
 *                      - @a TIME_IMMEDIATE immediate timeout.
 *                      - @a TIME_INFINITE no timeout.
 * @return              The operation status.
 * @retval MSG_OK       if a buffer has been acquired.
 * @retval MSG_TIMEOUT  if the specified time expired.
 * @retval MSG_RESET    if the queue has been reset.
 * @api
msg_t ibqGetFullBufferTimeout(input_buffers_queue_t *ibqp,
                              systime_t timeout) {
  msg_t msg;
  osalSysLock();
  msg = ibqGetFullBufferTimeoutS(ibqp, timeout);
  osalSysUnlock();
  return msg;
   *          is empty.
   * @sclass
  msg_t ibqGetFullBufferTimeoutS(input_buffers_queue_t *ibqp,
  osalDbgCheckClassS();
  while (ibqIsEmptyI(ibqp)) {
    msg_t msg = osalThreadEnqueueTimeoutS(&ibqp->waiting, timeout);
    if (msg < MSG_OK) {
       return msg;
  osalDbgAssert(!ibqIsEmptyI(ibqp), "still empty");
  /* Setting up the "current" buffer and its boundary.*/
  ibqp->ptr = ibqp->brdptr + sizeof (size_t);
  ibqp->top = ibqp->ptr + *((size_t *)ibqp->brdptr);
  return MSG_OK;
 * @brief   Releases the buffer back in the queue.
 * @note    The object callback is called after releasing the buffer.
 * @api
void ibqReleaseEmptyBuffer(input_buffers_queue_t *ibqp) {
  osalSysLock();
  ibqReleaseEmptyBufferS(ibqp);
  osalSysUnlock();
   * @sclass
  void ibqReleaseEmptyBufferS(input_buffers_queue_t *ibqp) {
  osalDbgAssert(!ibqIsEmptyI(ibqp), "buffers queue empty");
  /* Freeing a buffer slot in the queue.*/
  ibqp->bcounter--;
  ibqp->brdptr += ibqp->bsize;
  if (ibqp->brdptr >= ibqp->btop) {
  /* No "current" buffer.*/
  ibqp->ptr = NULL;
  /* Notifying the buffer release.*/
  if (ibqp->notify != NULL) {
    ibqp->notify(ibqp);
 * @brief   Input queue read with timeout.
 * @details This function reads a byte value from an input queue. If
 *          the queue is empty then the calling thread is suspended until a
 *          new buffer arrives in the queue or a timeout occurs.
 * @return              A byte value from the queue.
 * @api
msg_t ibqGetTimeout(input_buffers_queue_t *ibqp, systime_t timeout) {
  msg_t msg;
  osalSysLock();
  /* This condition indicates that a new buffer must be acquired.*/
  if (ibqp->ptr == NULL) {
    if (msg != MSG_OK) {
      osalSysUnlock();
      return msg;
  /* Next byte from the buffer.*/
  msg = (msg_t)*ibqp->ptr;
  ibqp->ptr++;
  /* If the current buffer has been fully read then it is returned as
     empty in the queue.*/
  if (ibqp->ptr >= ibqp->top) {
  osalSysUnlock();
  return msg;
 * @details The function reads data from an input queue into a buffer.
 *          The operation completes when the specified amount of data has been
 *          transferred or after the specified timeout or if the queue has
 *          been reset.
 * @param[out] bp       pointer to the data buffer
 * @param[in] n         the maximum amount of data to be transferred, the
 *                      value 0 is reserved
 * @return              The number of bytes effectively transferred.
 * @retval 0            if a timeout occurred.
 * @api
size_t ibqReadTimeout(input_buffers_queue_t *ibqp, uint8_t *bp,
                      size_t n, systime_t timeout) {
  size_t r = 0;
  systime_t deadline;
  osalSysLock();
  /* Time window for the whole operation.*/
  deadline = osalOsGetSystemTimeX() + timeout;
  while (true) {
    size_t size;
      msg_t msg;
      /* TIME_INFINITE and TIME_IMMEDIATE are handled differently, no
         deadline.*/
      if ((timeout == TIME_INFINITE) || (timeout == TIME_IMMEDIATE)) {
      else {
        systime_t next_timeout = deadline - osalOsGetSystemTimeX();
        /* Handling the case where the system time went past the deadline,
           in this case next becomes a very high number because the system
           time is an unsigned type.*/
        if (next_timeout > timeout) {
          osalSysUnlock();
          return r;
        msg = ibqGetFullBufferTimeoutS(ibqp, next_timeout);
      /* Anything except MSG_OK interrupts the operation.*/
        osalSysUnlock();
        return r;
    /* Size of the data chunk present in the current buffer.*/
    size = (size_t)ibqp->top - (size_t)ibqp->ptr;
    if (size > (n - r)) {
      size = n - r;
    /* Smaller chunks in order to not make the critical zone too long,
       this impacts throughput however.*/
    if (size > 64U) {
      /* Giving the compiler a chance to optimize for a fixed size move.*/
      memcpy(bp, ibqp->ptr, 64U);
      bp        += 64U;
      ibqp->ptr += 64U;
      r         += 64U;
    else {
      memcpy(bp, ibqp->ptr, size);
      bp        += size;
      ibqp->ptr += size;
      r         += size;
    /* Has the current data buffer been finished? if so then release it.*/
    /* Giving a preemption chance.*/
    osalSysUnlock();
    if (r >= n) {
      return r;
    osalSysLock();
 * @brief   Initializes an output buffers queue object.
 * @param[out] obqp     pointer to the @p output_buffers_queue_t object
 * @param[in] onfy      callback called when a buffer is posted in the queue
 * @init
void obqObjectInit(output_buffers_queue_t *obqp, uint8_t *bp,
                   bqnotify_t onfy, void *link) {
  osalDbgCheck((obqp != NULL) && (bp != NULL) && (size >= 2U));
  osalThreadQueueObjectInit(&obqp->waiting);
  obqp->bcounter = n;
  obqp->brdptr   = bp;
  obqp->bwrptr   = bp;
  obqp->btop     = bp + ((size + sizeof (size_t)) * n);
  obqp->bsize    = size + sizeof (size_t);
  obqp->bn       = n;
  obqp->buffers  = bp;
  obqp->ptr      = NULL;
  obqp->top      = NULL;
  obqp->notify   = onfy;
  obqp->link     = link;
 * @brief   Resets an output buffers queue.
 * @details All the data in the output buffers queue is erased and lost, any
 * @param[in] obqp      pointer to the @p output_buffers_queue_t object
 * @iclass
void obqResetI(output_buffers_queue_t *obqp) {
  obqp->bcounter = bqSizeX(obqp);
  obqp->brdptr   = obqp->buffers;
  obqp->bwrptr   = obqp->buffers;
  obqp->ptr      = NULL;
  obqp->top      = NULL;
  osalThreadDequeueAllI(&obqp->waiting, MSG_RESET);
 * @param[out] sizep    pointer to the filled buffer size
 * @return              A pointer to the filled buffer.
 * @retval NULL         if the queue is empty.
 * @iclass
uint8_t *obqGetFullBufferI(output_buffers_queue_t *obqp,
                           size_t *sizep) {
  if (obqIsEmptyI(obqp)) {
    return NULL;
  /* Buffer size.*/
  *sizep = *((size_t *)obqp->brdptr);
  return obqp->brdptr + sizeof (size_t);
 * @brief   Releases the next filled buffer back in the queue.
 * @iclass
void obqReleaseEmptyBufferI(output_buffers_queue_t *obqp) {
  osalDbgAssert(!obqIsEmptyI(obqp), "buffers queue empty");
  obqp->bcounter++;
  obqp->brdptr += obqp->bsize;
  if (obqp->brdptr >= obqp->btop) {
  osalThreadDequeueNextI(&obqp->waiting, MSG_OK);
 *          is empty.
 * @api
msg_t obqGetEmptyBufferTimeout(output_buffers_queue_t *obqp,
  msg_t msg;
  osalSysLock();
  msg = obqGetEmptyBufferTimeoutS(obqp, timeout);
  osalSysUnlock();
  return msg;
   *          is empty.
   * @sclass
  msg_t obqGetEmptyBufferTimeoutS(output_buffers_queue_t *obqp,
  while (obqIsFullI(obqp)) {
    msg_t msg = osalThreadEnqueueTimeoutS(&obqp->waiting, timeout);
    if (msg < MSG_OK) {
      return msg;
  osalDbgAssert(!obqIsFullI(obqp), "still full");
  obqp->ptr = obqp->bwrptr + sizeof (size_t);
  obqp->top = obqp->bwrptr + obqp->bsize;
  return MSG_OK;
 * @api
void obqPostFullBuffer(output_buffers_queue_t *obqp, size_t size) {
  osalSysLock();
  obqPostFullBufferS(obqp, size);
  osalSysUnlock();
 * @sclass
void obqPostFullBufferS(output_buffers_queue_t *obqp, size_t size) {
  osalDbgCheck((size > 0U) && (size <= (obqp->bsize - sizeof (size_t))));
  osalDbgAssert(!obqIsFullI(obqp), "buffers queue full");
  *((size_t *)obqp->bwrptr) = size;
  obqp->bcounter--;
  obqp->bwrptr += obqp->bsize;
  if (obqp->bwrptr >= obqp->btop) {
  obqp->ptr = NULL;
  if (obqp->notify != NULL) {
    obqp->notify(obqp);
 * @brief   Output queue write with timeout.
 * @details This function writes a byte value to an output queue. If
 *          the queue is full then the calling thread is suspended until a
 *          new buffer is freed in the queue or a timeout occurs.
 * @param[in] b         byte value to be transferred
 * @api
msg_t obqPutTimeout(output_buffers_queue_t *obqp, uint8_t b,
  msg_t msg;
  osalSysLock();
  if (obqp->ptr == NULL) {
      osalSysUnlock();
      return msg;
  /* Writing the byte to the buffer.*/
  *obqp->ptr = b;
  obqp->ptr++;
  /* If the current buffer has been fully written then it is posted as
     full in the queue.*/
  if (obqp->ptr >= obqp->top) {
    obqPostFullBufferS(obqp, obqp->bsize - sizeof (size_t));
  osalSysUnlock();
  return MSG_OK;
 * @details The function writes data from a buffer to an output queue. The
 *          operation completes when the specified amount of data has been
 *          been reset.
 * @param[in] bp        pointer to the data buffer
 * @api
size_t obqWriteTimeout(output_buffers_queue_t *obqp, const uint8_t *bp,
  size_t w = 0;
  systime_t deadline;
  osalSysLock();
  while (true) {
    size_t size;
      msg_t msg;
         deadline.*/
      else {
          osalSysUnlock();
          return w;
        msg = obqGetEmptyBufferTimeoutS(obqp, next_timeout);
        osalSysUnlock();
        return w;
    /* Size of the space available in the current buffer.*/
    size = (size_t)obqp->top - (size_t)obqp->ptr;
    if (size > (n - w)) {
      size = n - w;
    if (size > 64U) {
      memcpy(obqp->ptr, bp, 64U);
      bp        += 64U;
      obqp->ptr += 64U;
      w         += 64U;
    else {
      memcpy(obqp->ptr, bp, size);
      bp        += size;
      obqp->ptr += size;
      w         += size;
    osalSysUnlock();
    if (w >= n) {
      return w;
    osalSysLock();
 * @brief   Flushes the current, partially filled, buffer to the queue.
 * @note    The notification callback is not invoked because the function
 *          is meant to be called from ISR context. An operation status is
 *          returned instead.
 * @retval false        if no new filled buffer has been posted to the queue.
 * @retval true         if a new filled buffer has been posted to the queue.
 * @iclass
bool obqTryFlushI(output_buffers_queue_t *obqp) {
  /* If queue is empty and there is a buffer partially filled and
     it is not being written.*/
  if (obqIsEmptyI(obqp) && (obqp->ptr != NULL)) {
    size_t size = (size_t)obqp->ptr - ((size_t)obqp->bwrptr + sizeof (size_t));
    if (size > 0U) {
      obqp->bcounter--;
      obqp->ptr = NULL;
      return true;
  return false;
 * @api
void obqFlush(output_buffers_queue_t *obqp) {
  osalSysLock();
  /* If there is a buffer partially filled and not being written.*/
  if (obqp->ptr != NULL) {
    size_t size = (size_t)obqp->ptr - (size_t)obqp->bwrptr;
    if (size > 0U) {
  osalSysUnlock();
midimon
Post by midimon »
Thank You, Giovanni, very much!
Now the new code works very well :).
