Hi!
I have a STM32F746G-Discovery board and I need to run Ugfx & ChibiOS together.
I tested the chibios demo and works fine!
I tested the ugfx demo and works fine!
But when I integrate both the display stops working
Someone could integrate Chibios & Ugfx in this board?
Thanks!
STM32F4746G-Discovery - ChibiOS & Ugfx
Re: STM32F4746G-Discovery - ChibiOS & Ugfx
Hello chelox!
Both ChibiOS/RT 2.6 and ChibiOS/RT 3.x are known to work very well with uGFX. In fact, most uGFX users use ChibiOS/RT as their underlying system as it's a great OS (hint: uGFX originated as a ChibiOS extension).
There's a known compatibility issue with the ST headers used by the uGFX example and the ST headers used by ChibiOS/RT. This is due to the fact that we (the uGFX people) added support for the STM32F746-Discovery board before there was any support on the ChibiOS/RT side. Therefore our bare-metal example for the STM32F746-Discovery uses the code from the STM32Cube HAL to initialize the LTDC, FMC, DMA2D and SDRAM. Sadly we didn't have time to check-up on the support status of the ChibiOS/HAL for the STM32F746 since then. In case of there's support now, the proper way to get this working is to write the uGFX board files using the ChibiOS/HAL. In case of there's currently no support for this platform in ChibiOS/HAL, you have to figure out whether the ST headers used by uGFX or the ones used by ChibiOS are 'the old ones' as there appears to be a version related compatibility issue that keeps the current STM32F746-Discovery demo from uGFX running on ChibiOS/RT.
You can find more information here: http://forum.ugfx.org/viewtopic.php?f=22&t=339 and here: http://forum.ugfx.org/viewtopic.php?f=23&t=334
We would really appreciate it if someone would take the time to resolve this issue. We are happy to help wherever we can!
