Problem with CanBus (STM32F407) when alone on bus.
jkozien
Post by jkozien »
Hello ,
I have a problem with CanBus operation in STM32F407 when my device is alone on bus then stops transmition and reception.
I must start other device first on bus - which transmit or receive frames and then switch on (or reset) my device with STM32F407 (ChibiOS) .
Then everything works.
My device can not first begin to send and receive because then stops working even then when other devices after several seconds (for example 15 seconds) starts correctly work on CanBus (then after reset STM32F407 my device starts working also(receive and transmit)).
Jaroslaw
Re: Problem with CanBus (STM32F407) when alone on bus.
I am not sure about what the problem could be here. Could it be related to HW (drivers, wiring, terminations etc)?
jkozien
Post by jkozien »
Thank you for replay.
I'm sure that hardware is ok.
I wrote a piece of code that sends a message and control descriptor fd.
      fd = canTransmit(&CAND1, 0, &CanFrameTX, MS2ST(10));
      if (fd < 0)
         chprintf((BaseSequentialStream *)&SD2, "Transmit fail \r\n");
         canStop(&CAND1);      //still restarting can until fd >=0
         canStart(&CAND1, &CurrentCanBusConfig);
When I add other device on canbus then fd = 0 and my device (after restarting Can) start working properly.
Jaroslaw
Try adding a delay before canStop(), it is possible that the clock is stopped while the unit is still trying to transmit.
jkozien
Post by jkozien »
It's no problem in this piece of code - this code is only a test loop , which detect the moment when I insert another transmitting/receiving device on CanBus. It's work (test loop) properly and correctly switch the CanBus on in my STM32F407 device. But if I only initialize CanBus in my STM32F407 device on startup (canStop()canStart()) then if my device is first on the bus - the CanBus driver never startup.
Normally this test loop doesn't exist in my code .
Test loop:
   while(true)
      chThdSleepMilliseconds(1000);
      if (fd < 0)
         chThdSleepMilliseconds(100);
         canStop(&CAND1);
If my device is connected to the bus while others are already working then there is no problem - my test loop is then not required.
It seems to me that the startup procedure does not work or the driver switches off when there is no incoming frames or no device receives frames.
One-time initialization code(startup procedure):
         chThdYield();
   canStop(&CAND1);
   canStart(&CAND1, config);
It is only once initialized at the start of the program.
The test application works even if there are no other devices transmitting. What is different in your case? could you try to set the loopback mode and see if the behavior is the same?
jkozien
Post by jkozien »
The test loop is working properly because it still restarting canbus, - (canStop -> canStart -> ... etc. ) without restarting it doesn't work too.
franek.bmw
Post by franek.bmw »
Jaroslaw, please show us your canbus configuration. I think there is problem.
Best regards,
Franek
jkozien
Post by jkozien »
My CanBus configuration:
           const CANConfig cancfg_500k = {
      CAN_MCR_TXFP ,
      CAN_BTR_SJW(0) | CAN_BTR_TS2(2) |
      CAN_BTR_TS1(9) | CAN_BTR_BRP(5)
franek.bmw
You must set bit ABOM, this solves your problem.
Your configuration should look like this:
      CAN_MCR_TXFP | CAN_MCR_ABOM ,
Let me know if this helps. :)
