[FEATURE REQUEST] More hooks
sdalu
Been thanked: 2 times
Post by sdalu »
It would be nice to have a few more CH_CFG_*_HOOK
The one I found missing for my needs are:
* CH_CFG_IRQ_PROLOGUE_HOOK, CH_CFG_IRQ_EPILOGUE_HOOK
* CH_CFG_SCHED_THREAD_READY_HOOK(tp), CH_CFG_SCHED_THREAD_SLEEP_HOOK(tp, newstate)
This would allow to easily interface with SystemView from Segger
( https://www.segger.com/systemview.html )
Re: [FEATURE REQUEST] More hooks
I will try to include this in RT4 and NIL2, both are currently under development.
BTW RT4 already supports an enhanced trace buffer that keeps track of all state changes and also ISR prologue/epilogue, you can see also ISR preempting other ISRs. Would be possible to use the information stored there? it is possible that hooks are not even required.
Read this thread: viewtopic.php?f=3&t=3094#p23986
Edit: CH_CFG_CONTEXT_SWITCH_HOOK should always allow to hook transitions to ready and to sleep, just check the states of the threads being switched in/out.
sdalu
Post by sdalu »
Great.
I'm already using the context switch hook, but SystemView seems to also make a distinction between "ready" ("Record a Task Start Ready event.") and "start" ("The Task Start event corresponds to when a task has started to execute rather than when it is ready to execute.").* Which I interpreted as the chReady and chSysSwich.
Don't know if the trace buffer could be enough to interface with SystemView (the difficult part to use a closed source program, any alternative is welcomed), but it would surely be very nice to also have a hook in the trace buffer itself (in chDbgWriteTraceI?)
I just read the thread about the trace buffer. I'm wondering how the information is transfered from the board to the eclipse view. Is it by reading memory directly from the board using a jtag/swd?
Correct, it is done using the debugger interface.
Good idea about the trace hook, I will add that tomorrow.
Note you know when the thread starts executing, it is when it goes CH_STATE_CURRENT after being created, you have both info.
#define CH_STATE_READY      (tstate_t)0      /**< @brief Waiting on the
                                                  ready list.               */
#define CH_STATE_CURRENT    (tstate_t)1      /**< @brief Currently running. */
#define CH_STATE_WTSTART    (tstate_t)2      /**< @brief Just created.      */
#define CH_STATE_SUSPENDED  (tstate_t)3      /**< @brief Suspended state.   */
#define CH_STATE_QUEUED     (tstate_t)4      /**< @brief On an I/O queue.   */
#define CH_STATE_WTSEM      (tstate_t)5      /**< @brief On a semaphore.    */
#define CH_STATE_WTMTX      (tstate_t)6      /**< @brief On a mutex.        */
#define CH_STATE_WTCOND     (tstate_t)7      /**< @brief On a cond.variable.*/
#define CH_STATE_SLEEPING   (tstate_t)8      /**< @brief Sleeping.          */
#define CH_STATE_WTEXIT     (tstate_t)9      /**< @brief Waiting a thread.  */
#define CH_STATE_WTOREVT    (tstate_t)10     /**< @brief One event.         */
#define CH_STATE_WTANDEVT   (tstate_t)11     /**< @brief Several events.    */
#define CH_STATE_SNDMSGQ    (tstate_t)12     /**< @brief Sending a message,
                                                  in queue.                 */
#define CH_STATE_SNDMSG     (tstate_t)13     /**< @brief Sent a message,
                                                  waiting answer.          */
#define CH_STATE_WTMSG      (tstate_t)14     /**< @brief Waiting for a
                                                  message.                  */
#define CH_STATE_FINAL      (tstate_t)15     /**< @brief Thread terminated. */
fjb
Post by fjb »
I just found this thread because I try to add Segger SystemView support to my project which is based on ChibiOS 3.1 at the moment.
I tried to use the context switch hook but I ran into locking errors. The SystemView integration sources don't have anything like the I-class API.
#define CH_CFG_CONTEXT_SWITCH_HOOK(ntp, otp) {                              \
   SEGGER_SYSVIEW_OnTaskStopExec();                              \
   SEGGER_SYSVIEW_OnTaskStartExec((unsigned)ntp);                     \
sdalu
Post by sdalu »
Locking is #define in SEGGER_RTT_Conf.h.
You can use empty definitions:
#define SEGGER_RTT_LOCK()
#define SEGGER_RTT_UNLOCK()
fjb
Post by fjb »
Thank you. That works. I have to do the locking outside the kernel on my own with this solution, but that should be no problem.
Now I ran in a stack overflow issue. I have the feeling that I have to make all stacks bigger or I didn't find the offending stack yet.
Note that there are hooks for thread creation and exit.
In RT4 (now in trunk) there are all the required hook for that tool to work.
sdalu
Post by sdalu »
when using Segger_RTT_printf, I use PORT_INT_REQUIRED_STACK=256
It takes a lot of RAM, that value is added to all threads.
