Hi I compile my code in Chibistudio and get this error . Could you help me please?
Description Resource Path Location Type
make: *** No rule to make target `../ChibiOS-RT/os/ports/GCC/ARMCMx/crt0.c', needed by `build/obj/crt0.o'. Stop. BallBalancing_ChibiOSRT C/C++ Problem
and aslo
make: *** No rule to make target `BallBalancing_ChibiOSRT_scd.mk'. Stop. BallBalancing_ChibiOSRT [Discovery Options] page in project properties C/C++ Problem
Error in Chibisutdio
Re: Error in Chibisutdio
It is a make message, it means that some of the files specified in .mk files are not there, verify paths.
about this
I have to find a file named crt0.o and add it there ?!
I have another problem I have downloaded the 15.7z version of Chibistudio. It has two icons for starting a program Chibi Studio GCC 4.7 and Chibi Studio GCC 4.9 and it has three folders for workspace,
workspace_trunk, workspace26 and workspace30 ! which one of these folders should I use because I think the problem is related to these !!
Download the lastest ChibiStudio v16 and use the default workspace, it is the latest official version. Try compiling one of the existing demos, then clone the project (^c/^v in project explorer), start from the copy for your project.
There is something else and I appreciate it if you help me. I have a project that consists of two parts or folders. One is for win32 and the other for Chibios. I want to know when there is a project like this we import both these files in Chibios and run and because of the instructions in the program they will run simultaneously ?
I don't get this error please tell me what to do
I found the file crt0.c and copied it and changed it to crt0.o but again I get the same error !
smjh1371 wrote:I don't get this error please tell me what to do
I can't help with the problem here.
Anyway, the error is about crt0.c or crrt0.s not being in the expected position. I suggest to download the latest version and start over.
the new version has 4 workspaces . Is there any difference between them or they are the same? which one should I use?
The default one contains the latest official code (16.1). Others are older versions or experimental code.
