Problem with OpenOCD and CMSIS-DAP
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Post by RoccoMarco »
I am experimenting some issues trying to flash and run a Kinetis demo (RT-FREEDOM-KL25Z).
Well, I am usign CMSIS-DAP so I have created a new entry in external tools: it launches OpenOCD with this arguments:
-c  "telnet_port 4444"  -s "C:\ChibiStudio\tools\openocd\scripts" -f "interface/cmsis-dap.cfg" -f "${file_prompt}"
Launching it on prompt I have chosen "target\kl25.cfg" I obtained
Open On-Chip Debugger 0.10.0-dev-00200-gdb56a3b (2016-02-10-18:08)
Licensed under GNU GPL v2
For bug reports, read
   http://openocd.org/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'swd'
Info : add flash_bank kinetis kl25.flash
adapter speed: 1000 kHz
none separate
cortex_m reset_config sysresetreq
Info : CMSIS-DAP: SWD  Supported
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : CMSIS-DAP: FW Version = 1.0
Info : SWCLK/TCK = 0 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 1000 kHz
Info : SWD IDCODE 0x0bc11477
Info : kl25.cpu: hardware has 2 breakpoints, 2 watchpoints
Info : MDM: Chip is unsecured. Continuing.
On flash and run I received this error
symbol-file C:\\ChibiStudio\\chibios161\\demos\\KINETIS\\RT-FREEDOM-KL25Z\\build\\ch.elf
Reading symbols from C:\ChibiStudio\chibios161\demos\KINETIS\RT-FREEDOM-KL25Z\build\ch.elf...done.
set remotetimeout 20
monitor reset init
"monitor" command not supported by this target.
monitor sleep 50
load C:\\ChibiStudio\\chibios161\\demos\\KINETIS\\RT-FREEDOM-KL25Z\\build\\ch.elf
You can't do that when your target is `None'
tbreak main
Cannot access memory at address 0x5422
continue
The program is not being run.
Most likely there is something wrong with debug configuration and related commands. Any suggestions?
acr
Re: Problem with OpenOCD and CMSIS-DAP
Post by acr »
u run target extended-remote localhost:3333 ?
before symbol-file ?
RoccoMarco
I have solved my problem. Actually the problem is due to non halted target. I have issued an halt editing the configuration file "target\klx.cfg"
# Freescale Kinetis KL series devices
source [find target/swj-dp.tcl]
if { [info exists CHIPNAME] } {
    set _CHIPNAME $CHIPNAME
} else {
    set _CHIPNAME klx
# Work-area is a space in RAM used for flash programming
# By default use 4kB
if { [info exists WORKAREASIZE] } {
   set _WORKAREASIZE $WORKAREASIZE
} else {
   set _WORKAREASIZE 0x1000
if { [info exists CPUTAPID] } {
    set _CPUTAPID $CPUTAPID
} else {
    set _CPUTAPID 0x0bc11477
swj_newdap $_CHIPNAME cpu -irlen 4 -expected-id $_CPUTAPID
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME cortex_m -chain-position $_CHIPNAME.cpu
# It is important that "kinetis mdm check_security" is called for
# 'examine-end' event and not 'eximine-start'. Calling it in 'examine-start'
# causes "kinetis mdm check_security" to fail the first time openocd
# calls it when it tries to connect after the CPU has been power-cycled.
$_CHIPNAME.cpu configure -event examine-end {
$_TARGETNAME configure -work-area-phys 0x20000000 -work-area-size $_WORKAREASIZE -work-area-backup 0
set _FLASHNAME $_CHIPNAME.flash
flash bank $_FLASHNAME kinetis 0 0 0 0 $_TARGETNAME
# Table 5-1. Clock Summary of KL25 Sub-Family Reference Manual
# specifies up to 1MHz for VLPR mode.
adapter_khz 1000
$_TARGETNAME configure -event gdb-attach {
  halt
reset_config srst_nogate
if {![using_hla]} {
   # if srst is not fitted use SYSRESETREQ to
   # perform a soft reset
$_TARGETNAME configure -event reset-init {
    # specifies up to 24MHz for run mode; Table 17 of Sub-Family Data
    # Sheet rev4 lists 25MHz as the maximum frequency.
    adapter_khz 24000
I have configured the event gdb-attach
  halt
Now debugger works correctly.
Anyway I found out another issue!
OpenOCD loses target control right after a the flash and run if optimization are enabled.
This is due to a wrong configuration of the memory section named ".cfmconfig" (flash memory from 0x0000_0400 to 0x0000_0410).
Opening ports/KINETIS/KL2x/hal_lld.c you can see that a configuration is attempted
/* Driver local variables and types.                                         */
#ifdef __CC_ARM
__attribute__ ((section(".ARM.__at_0x400")))
#else
__attribute__ ((section(".cfmconfig")))
const uint8_t _cfm[0x10] = {
  0xFF,  /* NV_BACKKEY3: KEY=0xFF */
  0xFF,  /* NV_BACKKEY2: KEY=0xFF */
  0xFF,  /* NV_BACKKEY1: KEY=0xFF */
  0xFF,  /* NV_BACKKEY0: KEY=0xFF */
  0xFF,  /* NV_BACKKEY7: KEY=0xFF */
  0xFF,  /* NV_BACKKEY6: KEY=0xFF */
  0xFF,  /* NV_BACKKEY5: KEY=0xFF */
  0xFF,  /* NV_BACKKEY4: KEY=0xFF */
  0xFF,  /* NV_FPROT3: PROT=0xFF */
  0xFF,  /* NV_FPROT2: PROT=0xFF */
  0xFF,  /* NV_FPROT1: PROT=0xFF */
  0xFF,  /* NV_FPROT0: PROT=0xFF */
  0x7E,  /* NV_FSEC: KEYEN=1,MEEN=3,FSLACC=3,SEC=2 */
  0xFF,  /* NV_FOPT: ??=1,??=1,FAST_INIT=1,LPBOOT1=1,RESET_PIN_CFG=1,
                      NMI_DIS=1,EZPORT_DIS=1,LPBOOT0=1 */
  0xFF,
  0xFF
Anyway without a volatile this is ignored when optimization are enabled. I have solved this problem editing hal_lld.h
#ifdef __CC_ARM
volatile __attribute__ ((section(".ARM.__at_0x400")))
#else
volatile __attribute__ ((section(".cfmconfig")))
  0xFF,
  0xFF
Ciao,
RM
utzig
Been thanked: 20 times
Post by utzig »
I could reproduce here. Enabling LTO is really removing the section. I'll update the hal_lld's for Kinetis to add volatile that works both with LTO yes/no. Good catch!
RoccoMarco
thanks utzig
flabbergast
Post by flabbergast »
utzig wrote:I could reproduce here. Enabling LTO is really removing the section. I'll update the hal_lld's for Kinetis to add volatile that works both with LTO yes/no. Good catch!
I reported this last September here: viewtopic.php?f=26&t=2765#p22321 but I guess I drowned it with my other posts ;)
My solution was to add 'used' flag, but 'volatile' should work as well.
utzig
Post by utzig »
flabbergast wrote:I reported this last September here: viewtopic.php?f=26&t=2765#p22321 but I guess I drowned it with my other posts ;)
Actually I applied your suggestion to the K20x port. Just forgot to apply it too to KL2x! :P
Fixed now, thanks!
utzig
Post by utzig »
Ops, the change to K20x/hal_lld.c was just local, I forgot to commit at all... done now!
