Start ADC Conversion from within ADC conversion callback
Alex
Post by Alex »
Can i call start adc conversion from within callback of previous adc conversion?
My approaches was unsuccessfull..
for example: (reconstruction, may be small errors)
void adc1_callback(ADCDriver *adcp, adcsample_t *buffer, size_t n)
  adcStartConversionI(adcp, &adc_grp_cfg2, &sample_2, ADC_GRP2_NUM_CHANNELS);
// conversion group for previous conversion
static const ADCConversionGroup adc_grp_cfg1 = {
  FALSE,
  1,
  adc1_callback,
  NULL,
  .u.adc = {
      0, ADC_CR2_SWSTART, 0, 0,
    { 0,     ADC_SMPR2_SMP_AN8(ADC_SAMPLE_1P5)},
    { 0, 0,  ADC_SQR3_SQ1_N(ADC_CHANNEL_IN8 ) }
// conversion group for next conversion
static const ADCConversionGroup adc_cfg_grp2 = {
  FALSE,
  ADC_WDG_NUM_CHANNELS,
  NULL,
  adcerr_wdg,
  .u.adc = {
    ADC_CR1_AWDEN | ADC_CR1_AWDIE | ADC_CR1_AWDSGL | ADC_CR1_AWDCH_0 | ADC_CR1_AWDCH_3,
      ADC_CR2_SWSTART | ADC_CR2_CONT,
      NEGATIVE_VOLTAGE_LIMIT,
      POSITIVE_VOLTAGE_LIMIT,
    { 0,     ADC_SMPR2_SMP_AN9(ADC_SAMPLE_1P5)},
    { 0, 0,  ADC_SQR3_SQ1_N(ADC_CHANNEL_IN9)}}};
Re: Start ADC Conversion from within ADC conversion callbac
It should work. You are not defining "unsuccessful".
Alex
Post by Alex »
Thank you!
To define "unsuccessfull" need too many words...
You should give a minimum of info when asking for support, at very least what you expect and what you are getting instead. Specifying also the device used, the ChibiOS version would be useful too.
Alex
Post by Alex »
Sorry, but i don't wait no more anything..
Device - STM32F373C8T6, OS - Nil from ChibiOs 3.0
great respect !
It was not my intention to offend you, I just needed more info in order to give support.
Alex
Post by Alex »
Same problem, other side look:
this conversion group:
static const ADCConversionGroup adc_cfg_wdg2 = {
  FALSE,
  2,
  NULL,
  adcerr_wdg,
  .u.adc = {
    { 0,     ADC_SMPR2_SMP_AN8(ADC_SAMPLE_1P5) | ADC_SMPR2_SMP_AN9(ADC_SAMPLE_1P5)},
    { 0, 0,  ADC_SQR3_SQ2_N(ADC_CHANNEL_IN8)   | ADC_SQR3_SQ1_N(ADC_CHANNEL_IN9)}}};
and this call conversion
adcStartConversionI(&ADCD1, &adc_cfg_wdg2, buf, ADC_WDG_BUFDEPTH);
if ADC_WDG_BUFDEPTH > 0, store results of conversion, but not call adcerr_wdg
if ADC_WDG_BUFDEPTH == 0, call adcerr_wdg, but not store results of conversion, in same conditions
I want both actions: store results of conversion, and call adcerr_wdg - this is possible?
clear up a point: I am interested in: result of conversion at channel 8 once of certain time period,
and check ranges signal at channel 9 during whole this period
PS: Device STM32F373C8T6, board- self made, OS - NIL from ChibiOs v3.0
PPS: Sorry for my Engish ...
thank you very much for you tolerance
