halconf and mcuconf for pwm: #error compile time
enrico.dallavia
Post by enrico.dallavia »
I have a problem I don't understand. I'm using stm072R8-discovery board, and I'm trying to bring up various functionality: ADC, DAC, watchdog, PWM output.
I'm facing a problem with pwm.
after enabling in halconf.h
#if !defined(HAL_USE_PWM) || defined(__DOXYGEN__)
#define HAL_USE_PWM                 TRUE
and inside mcuconf.h
 * PWM driver system settings.
#define STM32_PWM_USE_ADVANCED              FALSE
#define STM32_PWM_USE_TIM1                  FALSE
#define STM32_PWM_USE_TIM2                  TRUE
#define STM32_PWM_USE_TIM3                  FALSE
#define STM32_PWM_TIM1_IRQ_PRIORITY         3
#define STM32_PWM_TIM2_IRQ_PRIORITY         3
#define STM32_PWM_TIM3_IRQ_PRIORITY         3
I got #error "ST requires TIM2 but the timer is already used"
The pin I'm using is PB3 that corresponds to TIM2_CH2 and I don't think I'm using TIM2 for other functionality
What could be the problem?
Thanks
Re: halconf and mcuconf for pwm: #error compile time
Used by the ST driver.
enrico.dallavia
Thanks for the answer, but I don't understand.
you mean TIM2 is already used by st driver for something else? If yes, for what?
Documentation is your friend http://chibios.sourceforge.net/docs3/ha ... __s_t.html
enrico.dallavia
Indeed it is!!
so TIM2 is used by Chibios if I'm not mistaken
This module implements a system tick timer in order to support the underlying operating system.
That means TIM2 will not be ever available for anything?
You can free it by disabling the tickless mode.
enrico.dallavia
Ok, thanks.
could you kindly answer me one more question?
If I'm disabling the thickless, what are the drawbacks? I can't use, for example,chVTGetSystemTimeX() function?
from this thread [url]
viewtopic.php?f=3&t=339
[/url]
I see that timeout also stop working, that means every function that got a timeout parameter as input, will stop working?
also chThdSleepMilliseconds(xxx); will stop working?
I see now from the source code that also TIM3 is needed by the low level driver.
That means only TIM1 is free to be used by application code?
enrico.dallavia
from another post I understand that it is possible to choose which timer must be used for systick
here
[url]
viewtopic.php?f=24&t=2280
[/url]
changing the line
#define STM32_ST_USE_TIMER 3
enrico.dallavia
but it does not work, since TIM3 is not a 32 bit timer :(
enrico.dallavia
from here
[url]
http://www.chibios.org/dokuwiki/doku.ph ... :kernel_vt
[/url]
it seems that if I disable thickless mode, the power consumption will increase, CPU usage is increased by the frequent IRQ servicing, ecc...
but the other functions should work as usual? Should I reduce the system resolution from 10000 to 1000 to reduce the impact on the system?
