Problem with SPI
sapan
Problem with SPI
Post by sapan »
I am using chibios on STM32F4 board. Sample codes in version 2.4.0 works fine on F4 discovery board, but when i tried to port same on my custom made board SPI doesnt work properly. I am using SPI available on PA4,5,6 and 7. Output on CRO is attached. I have checked GPIO in ouput mode and its giving perfect output. Any suggestions?
Sapan
spi output.png (94.36 KiB) Viewed 6551 times
Re: Problem with SPI
You should verify the settings in your board.h and the SPI initialization in main.c.
sapan
Post by sapan »
Following are setting for port A in board.h file
#define VAL_GPIOA_MODER (PIN_MODE_INPUT(0) | \
PIN_MODE_INPUT(1) | \
PIN_MODE_INPUT(2) | \
PIN_MODE_INPUT(3) | \
PIN_MODE_OUTPUT(4) | \
PIN_MODE_ALTERNATE(5) | \
PIN_MODE_ALTERNATE(6) | \
PIN_MODE_ALTERNATE(7) | \
PIN_MODE_ALTERNATE(8) | \
PIN_MODE_OUTPUT(GPIOA_VBUS_FS) | \
PIN_MODE_OUTPUT(GPIOA_OTG_FS_ID) | \
PIN_MODE_OUTPUT(GPIOA_OTG_FS_DM) | \
PIN_MODE_OUTPUT(GPIOA_OTG_FS_DP) | \
PIN_MODE_OUTPUT(GPIOA_SWDIO) | \
PIN_MODE_OUTPUT(GPIOA_SWCLK) | \
PIN_MODE_INPUT(15))
#define VAL_GPIOA_OTYPER 0x00000000 //PIN_OTYPE_OPENDRAIN(8)// 0x00000000
#define VAL_GPIOA_OSPEEDR 0xFFFFFFFF
#define VAL_GPIOA_PUPDR (PIN_PUDR_PULLUP(0) | \
PIN_PUDR_PULLUP(1) | \
PIN_PUDR_PULLUP(2) | \
PIN_PUDR_PULLUP(3) | \
PIN_PUDR_FLOATING(4) | \
PIN_PUDR_FLOATING(5) | \
PIN_PUDR_FLOATING(6) | \
PIN_PUDR_FLOATING(7) | \
PIN_PUDR_FLOATING(8) | \
PIN_PUDR_FLOATING(GPIOA_VBUS_FS) | \
PIN_PUDR_FLOATING(GPIOA_OTG_FS_ID) | \
PIN_PUDR_FLOATING(GPIOA_OTG_FS_DM) | \
PIN_PUDR_FLOATING(GPIOA_OTG_FS_DP) | \
PIN_PUDR_PULLUP(GPIOA_SWDIO) | \
PIN_PUDR_PULLDOWN(GPIOA_SWCLK) | \
PIN_PUDR_PULLUP(15))
#define VAL_GPIOA_ODR 0xFFFFFFFF
#define VAL_GPIOA_AFRL (PIN_AFIO_AF(5,5) | PIN_AFIO_AF(6,5) | PIN_AFIO_AF(7,5))
#define VAL_GPIOA_AFRH (PIN_AFIO_AF(8, 4) | PIN_AFIO_AF(GPIOA_OTG_FS_ID, 10) | \
PIN_AFIO_AF(GPIOA_OTG_FS_DM, 10) | \
PIN_AFIO_AF(GPIOA_OTG_FS_DP, 10) | \
PIN_AFIO_AF(GPIOA_SWDIO, 0) | \
PIN_AFIO_AF(GPIOA_SWCLK, 0))
and SPI initialization in main function is
static const SPIConfig spi1cfg = {
NULL,
/*HW dependent part.*/
GPIOA,
4,
SPI_CR1_BR_0 | SPI_CR1_BR_1 | SPI_CR1_BR_2 | SPI_CR1_CPOL | SPI_CR1_CPHA
spiStart(&SPID1, &spi1cfg);
palSetPadMode(GPIOA, 4, PAL_MODE_OUTPUT_PUSHPULL);//
palSetPadMode(GPIOA, 5, PAL_MODE_ALTERNATE(5));//
palSetPadMode(GPIOA, 6, PAL_MODE_ALTERNATE(5));//
palSetPadMode(GPIOA, 7, PAL_MODE_ALTERNATE(5));//
Are these right or do I need to correct these?
I don't see any obvious error, could you post your whole main.c? just to verify if the SPI is invoked correctly.
I don't understand that picture much, exactly what do you see? all signal missing or just some of them missing? is the CS asserted? do you see the SPI clock?
Does application crash or just the SPI output is missing?
sapan
Post by sapan »
I am travelling for couple of days so wont be able to upload main file. The picture i have attached is signal level of sclk and as shown in picture its not going to zero logic. Let me get back and will upload complete files.
Thanks for prompt reply.
Sapan
OK, then it is unlikely it is a SW issue, is SCLK connected to something? is it possible this something is pulling it up?
sapan
Post by sapan »
Sorry for late reply. I am travelling right now.
Ok here is what I have tried so far. I have declared the SCK pin as GPIO and toggle it using SetPad and ClearPad function and introducting delay using ThdSleepMilliseconds. I was able to get perfect square wave. Maximum frequency I could get was 500 Hz. I tried ThdSleepMicroseconds also but it seems to be giving same frequency irresepective of values I passed. Next I will reduce frequency of external crystal (right now its 25 Mhz) and see what happens.
Sapan
sapan
Post by sapan »
Hi
Here is the mcuconf.h file which I am using for my customized board. Let me know if I have to make any modifications in this. I have altered value of STM32_PLLM_VALUE to 25.
Sapan
ChibiOS/RT - Copyright (C) 2006,2007,2008,2009,2010,
2011,2012 Giovanni Di Sirio.
This file is part of ChibiOS/RT.
ChibiOS/RT is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 3 of the License, or
(at your option) any later version.
ChibiOS/RT is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
A special exception to the GPL can be applied should you wish to distribute
a combined work that includes ChibiOS/RT, without being obliged to provide
the source code for any proprietary components. See the file exception.txt
for full details of how and when the exception can be applied.
* STM32F4xx drivers configuration.
* The following settings override the default settings present in
* the various device driver implementation headers.
* Note that the settings for each driver only have effect if the whole
* driver is enabled in halconf.h.
* IRQ priorities:
* 15...0 Lowest...Highest.
* DMA priorities:
* 0...3 Lowest...Highest.
* HAL driver system settings.
#define STM32_NO_INIT FALSE
#define STM32_HSI_ENABLED TRUE
#define STM32_LSI_ENABLED TRUE
#define STM32_HSE_ENABLED TRUE
#define STM32_LSE_ENABLED FALSE
#define STM32_CLOCK48_REQUIRED TRUE
#define STM32_SW STM32_SW_PLL
#define STM32_PLLSRC STM32_PLLSRC_HSE
#define STM32_PLLM_VALUE 25//8
#define STM32_PLLN_VALUE 336
#define STM32_PLLP_VALUE 2
#define STM32_PLLQ_VALUE 7
#define STM32_HPRE STM32_HPRE_DIV1
#define STM32_PPRE1 STM32_PPRE1_DIV4
#define STM32_PPRE2 STM32_PPRE2_DIV2
#define STM32_RTCSEL STM32_RTCSEL_LSI
#define STM32_RTCPRE_VALUE 8
#define STM32_MCO1SEL STM32_MCO1SEL_HSI
#define STM32_MCO1PRE STM32_MCO1PRE_DIV1
#define STM32_MCO2SEL STM32_MCO2SEL_SYSCLK
#define STM32_MCO2PRE STM32_MCO2PRE_DIV5
#define STM32_I2SSRC STM32_I2SSRC_CKIN
#define STM32_PLLI2SN_VALUE 192
#define STM32_PLLI2SR_VALUE 5
#define STM32_VOS STM32_VOS_HIGH
#define STM32_PVD_ENABLE FALSE
#define STM32_PLS STM32_PLS_LEV0
* ADC driver system settings.
#define STM32_ADC_ADCPRE ADC_CCR_ADCPRE_DIV2
#define STM32_ADC_USE_ADC1 TRUE
#define STM32_ADC_USE_ADC2 TRUE
#define STM32_ADC_USE_ADC3 TRUE
#define STM32_ADC_ADC1_DMA_STREAM STM32_DMA_STREAM_ID(2, 4)
#define STM32_ADC_ADC2_DMA_STREAM STM32_DMA_STREAM_ID(2, 2)
#define STM32_ADC_ADC3_DMA_STREAM STM32_DMA_STREAM_ID(2, 1)
#define STM32_ADC_ADC1_DMA_PRIORITY 2
#define STM32_ADC_ADC2_DMA_PRIORITY 2
#define STM32_ADC_ADC3_DMA_PRIORITY 2
#define STM32_ADC_IRQ_PRIORITY 5
#define STM32_ADC_ADC1_DMA_IRQ_PRIORITY 5
#define STM32_ADC_ADC2_DMA_IRQ_PRIORITY 5
#define STM32_ADC_ADC3_DMA_IRQ_PRIORITY 5
* CAN driver system settings.
#define STM32_CAN_USE_CAN1 TRUE
#define STM32_CAN_CAN1_IRQ_PRIORITY 11
* EXT driver system settings.
#define STM32_EXT_EXTI0_IRQ_PRIORITY 6
#define STM32_EXT_EXTI1_IRQ_PRIORITY 6
#define STM32_EXT_EXTI2_IRQ_PRIORITY 6
#define STM32_EXT_EXTI3_IRQ_PRIORITY 6
#define STM32_EXT_EXTI4_IRQ_PRIORITY 6
#define STM32_EXT_EXTI5_9_IRQ_PRIORITY 6
#define STM32_EXT_EXTI10_15_IRQ_PRIORITY 6
#define STM32_EXT_EXTI16_IRQ_PRIORITY 6
#define STM32_EXT_EXTI17_IRQ_PRIORITY 15
#define STM32_EXT_EXTI18_IRQ_PRIORITY 6
#define STM32_EXT_EXTI19_IRQ_PRIORITY 6
#define STM32_EXT_EXTI20_IRQ_PRIORITY 6
#define STM32_EXT_EXTI21_IRQ_PRIORITY 15
#define STM32_EXT_EXTI22_IRQ_PRIORITY 15
* GPT driver system settings.
#define STM32_GPT_USE_TIM1 FALSE
#define STM32_GPT_USE_TIM2 FALSE
#define STM32_GPT_USE_TIM3 FALSE
#define STM32_GPT_USE_TIM4 FALSE
#define STM32_GPT_USE_TIM5 FALSE
#define STM32_GPT_USE_TIM8 FALSE
#define STM32_GPT_TIM1_IRQ_PRIORITY 7
#define STM32_GPT_TIM2_IRQ_PRIORITY 7
#define STM32_GPT_TIM3_IRQ_PRIORITY 7
#define STM32_GPT_TIM4_IRQ_PRIORITY 7
#define STM32_GPT_TIM5_IRQ_PRIORITY 7
#define STM32_GPT_TIM8_IRQ_PRIORITY 7
* ICU driver system settings.
#define STM32_ICU_USE_TIM1 FALSE
#define STM32_ICU_USE_TIM2 FALSE
#define STM32_ICU_USE_TIM3 FALSE
#define STM32_ICU_USE_TIM4 TRUE
#define STM32_ICU_USE_TIM5 FALSE
#define STM32_ICU_USE_TIM8 FALSE
#define STM32_ICU_TIM1_IRQ_PRIORITY 7
#define STM32_ICU_TIM2_IRQ_PRIORITY 7
#define STM32_ICU_TIM3_IRQ_PRIORITY 7
#define STM32_ICU_TIM4_IRQ_PRIORITY 7
#define STM32_ICU_TIM5_IRQ_PRIORITY 7
#define STM32_ICU_TIM8_IRQ_PRIORITY 7
* PWM driver system settings.
#define STM32_PWM_USE_ADVANCED FALSE
#define STM32_PWM_USE_TIM1 FALSE
#define STM32_PWM_USE_TIM2 FALSE
#define STM32_PWM_USE_TIM3 FALSE
#define STM32_PWM_USE_TIM4 TRUE
#define STM32_PWM_USE_TIM5 FALSE
#define STM32_PWM_USE_TIM8 FALSE
#define STM32_PWM_TIM1_IRQ_PRIORITY 7
#define STM32_PWM_TIM2_IRQ_PRIORITY 7
#define STM32_PWM_TIM3_IRQ_PRIORITY 7
#define STM32_PWM_TIM4_IRQ_PRIORITY 7
#define STM32_PWM_TIM5_IRQ_PRIORITY 7
#define STM32_PWM_TIM8_IRQ_PRIORITY 7
#define STM32_SERIAL_USE_USART1 TRUE
#define STM32_SERIAL_USE_USART2 TRUE
#define STM32_SERIAL_USE_USART3 FALSE
#define STM32_SERIAL_USE_UART4 TRUE
#define STM32_SERIAL_USE_UART5 FALSE
#define STM32_SERIAL_USE_USART6 TRUE
#define STM32_SERIAL_USART1_PRIORITY 12
#define STM32_SERIAL_USART2_PRIORITY 12
#define STM32_SERIAL_USART3_PRIORITY 12
#define STM32_SERIAL_UART4_PRIORITY 12
#define STM32_SERIAL_UART5_PRIORITY 12
#define STM32_SERIAL_USART6_PRIORITY 12
* SPI driver system settings.
#define STM32_SPI_USE_SPI1 TRUE
#define STM32_SPI_USE_SPI2 TRUE
#define STM32_SPI_USE_SPI3 FALSE
#define STM32_SPI_SPI1_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 0)
#define STM32_SPI_SPI1_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 3)
#define STM32_SPI_SPI2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 3)
#define STM32_SPI_SPI2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_SPI_SPI3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 0)
#define STM32_SPI_SPI3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 7)
#define STM32_SPI_SPI1_DMA_PRIORITY 1
#define STM32_SPI_SPI2_DMA_PRIORITY 1
#define STM32_SPI_SPI3_DMA_PRIORITY 1
#define STM32_SPI_SPI1_IRQ_PRIORITY 10
#define STM32_SPI_SPI2_IRQ_PRIORITY 10
#define STM32_SPI_SPI3_IRQ_PRIORITY 10
#define STM32_SPI_DMA_ERROR_HOOK(spip) chSysHalt()
* UART driver system settings.
#define STM32_UART_USE_USART1 FALSE
#define STM32_UART_USE_USART2 TRUE
#define STM32_UART_USE_USART3 FALSE
#define STM32_UART_USART1_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 5)
#define STM32_UART_USART1_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 7)
#define STM32_UART_USART2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 5)
#define STM32_UART_USART2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 6)
#define STM32_UART_USART3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 1)
#define STM32_UART_USART3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 3)
#define STM32_UART_USART1_IRQ_PRIORITY 12
#define STM32_UART_USART2_IRQ_PRIORITY 12
#define STM32_UART_USART3_IRQ_PRIORITY 12
#define STM32_UART_USART1_DMA_PRIORITY 0
#define STM32_UART_USART2_DMA_PRIORITY 0
#define STM32_UART_USART3_DMA_PRIORITY 0
#define STM32_UART_DMA_ERROR_HOOK(uartp) chSysHalt()
* I2C driver system settings.
#define STM32_I2C_USE_I2C1 TRUE
#define STM32_I2C_USE_I2C2 FALSE
#define STM32_I2C_USE_I2C3 TRUE
#define STM32_I2C_I2C1_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 0)
#define STM32_I2C_I2C1_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 6)
#define STM32_I2C_I2C2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 2)
#define STM32_I2C_I2C2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 7)
#define STM32_I2C_I2C3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 2)
#define STM32_I2C_I2C3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_I2C_I2C1_IRQ_PRIORITY 6
#define STM32_I2C_I2C2_IRQ_PRIORITY 6
#define STM32_I2C_I2C3_IRQ_PRIORITY 6
#define STM32_I2C_I2C1_DMA_PRIORITY 1
#define STM32_I2C_I2C2_DMA_PRIORITY 1
#define STM32_I2C_I2C3_DMA_PRIORITY 1
#define STM32_I2C_I2C1_DMA_ERROR_HOOK() chSysHalt()
#define STM32_I2C_I2C2_DMA_ERROR_HOOK() chSysHalt()
#define STM32_I2C_I2C3_DMA_ERROR_HOOK() chSysHalt()
There is no need to change that divider in mcuconf.h, that way you are reducing the system clock frequency.
Try to modify the SPI initialization as follow:
palSetPadMode(GPIOA, 4, PAL_MODE_OUTPUT_PUSHPULL | PAL_STM32_OSPEED_HIGHEST);
palSetPadMode(GPIOA, 5, PAL_MODE_ALTERNATE(5) | PAL_STM32_OSPEED_HIGHEST);
palSetPadMode(GPIOA, 6, PAL_MODE_ALTERNATE(5) | PAL_STM32_OSPEED_HIGHEST);
palSetPadMode(GPIOA, 7, PAL_MODE_ALTERNATE(5) | PAL_STM32_OSPEED_HIGHEST);
It is possible it is simply a I/O speed issue.
sapan
Post by sapan »
I am using 25 Mhz crystal, therefore I have increase the value of PLLM so that final frequency would be 168 Mhz only. I have tried original code on discovery and SPI1 works fine at frequency of 300 KHz ( divider value is 256).
On my custom board there is no connections on SPI1. I am just checking clock on oscilloscope and its giving random output.
On discovery board crystal is 8 Mhz and all values in mcuconf.h are according to that value only (i.e. output frequency is 168 Mhz ). My question is apart from PLLM value which other value do i need to change so that SPI will work properly.
Sapan
