I am not an expert user, so I apoligize in advance if my question will seem silly.
I am developing a project with Chibios, HAL drivers on a STM32F4 discovery board. I am also using chibistudio.
GPTConfign is declared two times in my project:
the following piece of code is taken from os/hal/templates/gpt_lld.h
[spoil]typedef struct {
* @brief Timer clock in Hz.
* @note The low level can use assertions in order to catch invalid
* frequency specifications.
gptfreq_t frequency;
* @brief Timer callback pointer.
* @note This callback is invoked on GPT counter events.
gptcallback_t callback;
/* End of the mandatory fields.*/
} GPTConfig;[/spoil]
and the following is taken from os/hal/ports/STM32/LLD/TIMv1/gpt_lld.h
[spoil]struct GPTDriver {
* @brief Driver state.
gptstate_t state;
* @brief Current configuration data.
const GPTConfig *config;
#if defined(GPT_DRIVER_EXT_FIELDS)
* @brief Timer base clock.
uint32_t clock;
* @brief Pointer to the TIMx registers block.
stm32_tim_t *tim;
};[/spoil]
The same happens also for the data structure ADCConfig.
Why there are two of them? Which one I have to declare and then use in high level functions like gptStart() or gptStop()?
Thank you in advace for your patience and for your response.
Best regards,
Antonio.
P.S. this is my halconf
[spoil]/*
ChibiOS - Copyright (C) 2006..2015 Giovanni Di Sirio
* @file templates/halconf.h
* @brief HAL configuration header.
* @details HAL configuration file, this file allows to enable or disable the
* various device drivers from your application. You may also use
* this file in order to override the device drivers default settings.
* @addtogroup HAL_CONF
#ifndef _HALCONF_H_
#define _HALCONF_H_
#include "mcuconf.h"
* @brief Enables the PAL subsystem.
#if !defined(HAL_USE_PAL) || defined(__DOXYGEN__)
#define HAL_USE_PAL TRUE
* @brief Enables the ADC subsystem.
#if !defined(HAL_USE_ADC) || defined(__DOXYGEN__)
#define HAL_USE_ADC TRUE
* @brief Enables the CAN subsystem.
#if !defined(HAL_USE_CAN) || defined(__DOXYGEN__)
#define HAL_USE_CAN FALSE
* @brief Enables the DAC subsystem.
#if !defined(HAL_USE_DAC) || defined(__DOXYGEN__)
#define HAL_USE_DAC FALSE
* @brief Enables the EXT subsystem.
#if !defined(HAL_USE_EXT) || defined(__DOXYGEN__)
#define HAL_USE_EXT TRUE
* @brief Enables the GPT subsystem.
#if !defined(HAL_USE_GPT) || defined(__DOXYGEN__)
#define HAL_USE_GPT TRUE
* @brief Enables the I2C subsystem.
#if !defined(HAL_USE_I2C) || defined(__DOXYGEN__)
#define HAL_USE_I2C FALSE
* @brief Enables the I2S subsystem.
#if !defined(HAL_USE_I2S) || defined(__DOXYGEN__)
#define HAL_USE_I2S FALSE
* @brief Enables the ICU subsystem.
#if !defined(HAL_USE_ICU) || defined(__DOXYGEN__)
#define HAL_USE_ICU FALSE
* @brief Enables the MAC subsystem.
#if !defined(HAL_USE_MAC) || defined(__DOXYGEN__)
#define HAL_USE_MAC FALSE
* @brief Enables the MMC_SPI subsystem.
#if !defined(HAL_USE_MMC_SPI) || defined(__DOXYGEN__)
#define HAL_USE_MMC_SPI FALSE
* @brief Enables the PWM subsystem.
#if !defined(HAL_USE_PWM) || defined(__DOXYGEN__)
#define HAL_USE_PWM FALSE
* @brief Enables the RTC subsystem.
#if !defined(HAL_USE_RTC) || defined(__DOXYGEN__)
#define HAL_USE_RTC FALSE
* @brief Enables the SDC subsystem.
#if !defined(HAL_USE_SDC) || defined(__DOXYGEN__)
#define HAL_USE_SDC FALSE
* @brief Enables the SERIAL subsystem.
#if !defined(HAL_USE_SERIAL) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL TRUE
* @brief Enables the SERIAL over USB subsystem.
#if !defined(HAL_USE_SERIAL_USB) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL_USB FALSE
* @brief Enables the SPI subsystem.
#if !defined(HAL_USE_SPI) || defined(__DOXYGEN__)
#define HAL_USE_SPI FALSE
* @brief Enables the UART subsystem.
#if !defined(HAL_USE_UART) || defined(__DOXYGEN__)
#define HAL_USE_UART FALSE
* @brief Enables the USB subsystem.
#if !defined(HAL_USE_USB) || defined(__DOXYGEN__)
#define HAL_USE_USB FALSE
* @brief Enables the WDG subsystem.
#if !defined(HAL_USE_WDG) || defined(__DOXYGEN__)
#define HAL_USE_WDG FALSE
/* ADC driver related settings. */
* @brief Enables synchronous APIs.
* @note Disabling this option saves both code and data space.
#if !defined(ADC_USE_WAIT) || defined(__DOXYGEN__)
#define ADC_USE_WAIT TRUE
* @brief Enables the @p adcAcquireBus() and @p adcReleaseBus() APIs.
#if !defined(ADC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define ADC_USE_MUTUAL_EXCLUSION TRUE
/* CAN driver related settings. */
* @brief Sleep mode related APIs inclusion switch.
#if !defined(CAN_USE_SLEEP_MODE) || defined(__DOXYGEN__)
#define CAN_USE_SLEEP_MODE TRUE
/* I2C driver related settings. */
* @brief Enables the mutual exclusion APIs on the I2C bus.
#if !defined(I2C_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define I2C_USE_MUTUAL_EXCLUSION TRUE
/* MAC driver related settings. */
* @brief Enables an event sources for incoming packets.
#if !defined(MAC_USE_ZERO_COPY) || defined(__DOXYGEN__)
#define MAC_USE_ZERO_COPY FALSE
#if !defined(MAC_USE_EVENTS) || defined(__DOXYGEN__)
#define MAC_USE_EVENTS TRUE
/* MMC_SPI driver related settings. */
* @brief Delays insertions.
* @details If enabled this options inserts delays into the MMC waiting
* routines releasing some extra CPU time for the threads with
* lower priority, this may slow down the driver a bit however.
* This option is recommended also if the SPI driver does not
* use a DMA channel and heavily loads the CPU.
#if !defined(MMC_NICE_WAITING) || defined(__DOXYGEN__)
#define MMC_NICE_WAITING TRUE
/* SDC driver related settings. */
* @brief Number of initialization attempts before rejecting the card.
* @note Attempts are performed at 10mS intervals.
#if !defined(SDC_INIT_RETRY) || defined(__DOXYGEN__)
#define SDC_INIT_RETRY 100
* @brief Include support for MMC cards.
* @note MMC support is not yet implemented so this option must be kept
* at @p FALSE.
#if !defined(SDC_MMC_SUPPORT) || defined(__DOXYGEN__)
#define SDC_MMC_SUPPORT FALSE
#if !defined(SDC_NICE_WAITING) || defined(__DOXYGEN__)
#define SDC_NICE_WAITING TRUE
/* SERIAL driver related settings. */
* @brief Default bit rate.
* @details Configuration parameter, this is the baud rate selected for the
* default configuration.
#if !defined(SERIAL_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SERIAL_DEFAULT_BITRATE 38400
* @brief Serial buffers size.
* @details Configuration parameter, you can change the depth of the queue
* buffers depending on the requirements of your application.
* @note The default is 16 bytes for both the transmission and receive
* buffers.
#if !defined(SERIAL_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_BUFFERS_SIZE 16
/* SERIAL_USB driver related setting. */
* @brief Serial over USB buffers size.
* @details Configuration parameter, the buffer size must be a multiple of
* the USB data endpoint maximum packet size.
* @note The default is 256 bytes for both the transmission and receive
* buffers.
#if !defined(SERIAL_USB_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_SIZE 256
* @brief Serial over USB number of buffers.
* @note The default is 2 buffers.
#if !defined(SERIAL_USB_BUFFERS_NUMBER) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_NUMBER 2
/* SPI driver related settings. */
#if !defined(SPI_USE_WAIT) || defined(__DOXYGEN__)
#define SPI_USE_WAIT TRUE
* @brief Enables the @p spiAcquireBus() and @p spiReleaseBus() APIs.
#if !defined(SPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define SPI_USE_MUTUAL_EXCLUSION TRUE
/* UART driver related settings. */
#if !defined(UART_USE_WAIT) || defined(__DOXYGEN__)
#define UART_USE_WAIT FALSE
* @brief Enables the @p uartAcquireBus() and @p uartReleaseBus() APIs.
#if !defined(UART_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define UART_USE_MUTUAL_EXCLUSION FALSE
/* USB driver related settings. */
#if !defined(USB_USE_WAIT) || defined(__DOXYGEN__)
#define USB_USE_WAIT FALSE
* @brief Enables the USERLIB subsystem.
#if !defined(USERLIB_USE_LCD) || defined(__DOXYGEN__)
#define USERLIB_USE FALSE
#endif /* _HALCONF_H_ */
/** @} */[/spoil]
And this is my mcuconf
[spoil]/*
#ifndef _MCUCONF_H_
#define _MCUCONF_H_
* STM32F4xx drivers configuration.
* The following settings override the default settings present in
* the various device driver implementation headers.
* Note that the settings for each driver only have effect if the whole
* driver is enabled in halconf.h.
* IRQ priorities:
* 15...0 Lowest...Highest.
* DMA priorities:
* 0...3 Lowest...Highest.
#define STM32F4xx_MCUCONF
* HAL driver system settings.
#define STM32_NO_INIT FALSE
#define STM32_HSI_ENABLED TRUE
#define STM32_LSI_ENABLED TRUE
#define STM32_HSE_ENABLED TRUE
#define STM32_LSE_ENABLED FALSE
#define STM32_CLOCK48_REQUIRED TRUE
#define STM32_SW STM32_SW_PLL
#define STM32_PLLSRC STM32_PLLSRC_HSE
#define STM32_PLLM_VALUE 8
#define STM32_PLLN_VALUE 336
#define STM32_PLLP_VALUE 2
#define STM32_PLLQ_VALUE 7
#define STM32_HPRE STM32_HPRE_DIV1
#define STM32_PPRE1 STM32_PPRE1_DIV4
#define STM32_PPRE2 STM32_PPRE2_DIV2
#define STM32_RTCSEL STM32_RTCSEL_LSI
#define STM32_RTCPRE_VALUE 8
#define STM32_MCO1SEL STM32_MCO1SEL_HSI
#define STM32_MCO1PRE STM32_MCO1PRE_DIV1
#define STM32_MCO2SEL STM32_MCO2SEL_SYSCLK
#define STM32_MCO2PRE STM32_MCO2PRE_DIV5
#define STM32_I2SSRC STM32_I2SSRC_CKIN
#define STM32_PLLI2SN_VALUE 192
#define STM32_PLLI2SR_VALUE 5
#define STM32_PVD_ENABLE FALSE
#define STM32_PLS STM32_PLS_LEV0
#define STM32_BKPRAM_ENABLE FALSE
* ADC driver system settings.
#define STM32_ADC_ADCPRE ADC_CCR_ADCPRE_DIV4
#define STM32_ADC_USE_ADC1 TRUE
#define STM32_ADC_USE_ADC2 FALSE
#define STM32_ADC_USE_ADC3 FALSE
#define STM32_ADC_ADC1_DMA_STREAM STM32_DMA_STREAM_ID(2, 4)
#define STM32_ADC_ADC2_DMA_STREAM STM32_DMA_STREAM_ID(2, 2)
#define STM32_ADC_ADC3_DMA_STREAM STM32_DMA_STREAM_ID(2, 1)
#define STM32_ADC_ADC1_DMA_PRIORITY 2
#define STM32_ADC_ADC2_DMA_PRIORITY 2
#define STM32_ADC_ADC3_DMA_PRIORITY 2
#define STM32_ADC_IRQ_PRIORITY 6
#define STM32_ADC_ADC1_DMA_IRQ_PRIORITY 6
#define STM32_ADC_ADC2_DMA_IRQ_PRIORITY 6
#define STM32_ADC_ADC3_DMA_IRQ_PRIORITY 6
* CAN driver system settings.
#define STM32_CAN_USE_CAN1 FALSE
#define STM32_CAN_USE_CAN2 FALSE
#define STM32_CAN_CAN1_IRQ_PRIORITY 11
#define STM32_CAN_CAN2_IRQ_PRIORITY 11
* DAC driver system settings.
#define STM32_DAC_DUAL_MODE FALSE
#define STM32_DAC_USE_DAC1_CH1 FALSE
#define STM32_DAC_USE_DAC1_CH2 FALSE
#define STM32_DAC_DAC1_CH1_IRQ_PRIORITY 10
#define STM32_DAC_DAC1_CH2_IRQ_PRIORITY 10
#define STM32_DAC_DAC1_CH1_DMA_PRIORITY 2
#define STM32_DAC_DAC1_CH2_DMA_PRIORITY 2
#define STM32_DAC_DAC1_CH1_DMA_STREAM STM32_DMA_STREAM_ID(1, 5)
#define STM32_DAC_DAC1_CH2_DMA_STREAM STM32_DMA_STREAM_ID(1, 6)
* EXT driver system settings.
#define STM32_EXT_EXTI0_IRQ_PRIORITY 6
#define STM32_EXT_EXTI1_IRQ_PRIORITY 6
#define STM32_EXT_EXTI2_IRQ_PRIORITY 6
#define STM32_EXT_EXTI3_IRQ_PRIORITY 6
#define STM32_EXT_EXTI4_IRQ_PRIORITY 6
#define STM32_EXT_EXTI5_9_IRQ_PRIORITY 6
#define STM32_EXT_EXTI10_15_IRQ_PRIORITY 6
#define STM32_EXT_EXTI16_IRQ_PRIORITY 6
#define STM32_EXT_EXTI17_IRQ_PRIORITY 15
#define STM32_EXT_EXTI18_IRQ_PRIORITY 6
#define STM32_EXT_EXTI19_IRQ_PRIORITY 6
#define STM32_EXT_EXTI20_IRQ_PRIORITY 6
#define STM32_EXT_EXTI21_IRQ_PRIORITY 15
#define STM32_EXT_EXTI22_IRQ_PRIORITY 15
* GPT driver system settings.
#define STM32_GPT_USE_TIM1 TRUE
#define STM32_GPT_USE_TIM2 FALSE
#define STM32_GPT_USE_TIM3 FALSE
#define STM32_GPT_USE_TIM4 FALSE
#define STM32_GPT_USE_TIM5 FALSE
#define STM32_GPT_USE_TIM6 FALSE
#define STM32_GPT_USE_TIM7 FALSE
#define STM32_GPT_USE_TIM8 FALSE
#define STM32_GPT_USE_TIM9 FALSE
#define STM32_GPT_USE_TIM11 FALSE
#define STM32_GPT_USE_TIM12 FALSE
#define STM32_GPT_USE_TIM14 FALSE
#define STM32_GPT_TIM1_IRQ_PRIORITY 7
#define STM32_GPT_TIM2_IRQ_PRIORITY 7
#define STM32_GPT_TIM3_IRQ_PRIORITY 7
#define STM32_GPT_TIM4_IRQ_PRIORITY 7
#define STM32_GPT_TIM5_IRQ_PRIORITY 7
#define STM32_GPT_TIM6_IRQ_PRIORITY 7
#define STM32_GPT_TIM7_IRQ_PRIORITY 7
#define STM32_GPT_TIM8_IRQ_PRIORITY 7
#define STM32_GPT_TIM9_IRQ_PRIORITY 7
#define STM32_GPT_TIM11_IRQ_PRIORITY 7
#define STM32_GPT_TIM12_IRQ_PRIORITY 7
#define STM32_GPT_TIM14_IRQ_PRIORITY 7
* I2C driver system settings.
#define STM32_I2C_USE_I2C1 FALSE
#define STM32_I2C_USE_I2C2 FALSE
#define STM32_I2C_USE_I2C3 FALSE
#define STM32_I2C_BUSY_TIMEOUT 50
#define STM32_I2C_I2C1_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 0)
#define STM32_I2C_I2C1_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 6)
#define STM32_I2C_I2C2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 2)
#define STM32_I2C_I2C2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 7)
#define STM32_I2C_I2C3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 2)
#define STM32_I2C_I2C3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_I2C_I2C1_IRQ_PRIORITY 5
#define STM32_I2C_I2C2_IRQ_PRIORITY 5
#define STM32_I2C_I2C3_IRQ_PRIORITY 5
#define STM32_I2C_I2C1_DMA_PRIORITY 3
#define STM32_I2C_I2C2_DMA_PRIORITY 3
#define STM32_I2C_I2C3_DMA_PRIORITY 3
#define STM32_I2C_DMA_ERROR_HOOK(i2cp) osalSysHalt("DMA failure")
* I2S driver system settings.
#define STM32_I2S_USE_SPI2 FALSE
#define STM32_I2S_USE_SPI3 FALSE
#define STM32_I2S_SPI2_IRQ_PRIORITY 10
#define STM32_I2S_SPI3_IRQ_PRIORITY 10
#define STM32_I2S_SPI2_DMA_PRIORITY 1
#define STM32_I2S_SPI3_DMA_PRIORITY 1
#define STM32_I2S_SPI2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 3)
#define STM32_I2S_SPI2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_I2S_SPI3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 0)
#define STM32_I2S_SPI3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 7)
#define STM32_I2S_DMA_ERROR_HOOK(i2sp) osalSysHalt("DMA failure")
* ICU driver system settings.
#define STM32_ICU_USE_TIM1 FALSE
#define STM32_ICU_USE_TIM2 FALSE
#define STM32_ICU_USE_TIM3 FALSE
#define STM32_ICU_USE_TIM4 FALSE
#define STM32_ICU_USE_TIM5 FALSE
#define STM32_ICU_USE_TIM8 FALSE
#define STM32_ICU_USE_TIM9 FALSE
#define STM32_ICU_TIM1_IRQ_PRIORITY 7
#define STM32_ICU_TIM2_IRQ_PRIORITY 7
#define STM32_ICU_TIM3_IRQ_PRIORITY 7
#define STM32_ICU_TIM4_IRQ_PRIORITY 7
#define STM32_ICU_TIM5_IRQ_PRIORITY 7
#define STM32_ICU_TIM8_IRQ_PRIORITY 7
#define STM32_ICU_TIM9_IRQ_PRIORITY 7
* MAC driver system settings.
#define STM32_MAC_TRANSMIT_BUFFERS 2
#define STM32_MAC_RECEIVE_BUFFERS 4
#define STM32_MAC_BUFFERS_SIZE 1522
#define STM32_MAC_PHY_TIMEOUT 100
#define STM32_MAC_ETH1_CHANGE_PHY_STATE TRUE
#define STM32_MAC_ETH1_IRQ_PRIORITY 13
#define STM32_MAC_IP_CHECKSUM_OFFLOAD 0
* PWM driver system settings.
#define STM32_PWM_USE_ADVANCED FALSE
#define STM32_PWM_USE_TIM1 FALSE
#define STM32_PWM_USE_TIM2 FALSE
#define STM32_PWM_USE_TIM3 FALSE
#define STM32_PWM_USE_TIM4 FALSE
#define STM32_PWM_USE_TIM5 FALSE
#define STM32_PWM_USE_TIM8 FALSE
#define STM32_PWM_USE_TIM9 FALSE
#define STM32_PWM_TIM1_IRQ_PRIORITY 7
#define STM32_PWM_TIM2_IRQ_PRIORITY 7
#define STM32_PWM_TIM3_IRQ_PRIORITY 7
#define STM32_PWM_TIM4_IRQ_PRIORITY 7
#define STM32_PWM_TIM5_IRQ_PRIORITY 7
#define STM32_PWM_TIM8_IRQ_PRIORITY 7
#define STM32_PWM_TIM9_IRQ_PRIORITY 7
* SDC driver system settings.
#define STM32_SDC_SDIO_DMA_PRIORITY 3
#define STM32_SDC_SDIO_IRQ_PRIORITY 9
#define STM32_SDC_WRITE_TIMEOUT_MS 250
#define STM32_SDC_READ_TIMEOUT_MS 25
#define STM32_SDC_CLOCK_ACTIVATION_DELAY 10
#define STM32_SDC_SDIO_UNALIGNED_SUPPORT TRUE
#define STM32_SDC_SDIO_DMA_STREAM STM32_DMA_STREAM_ID(2, 3)
#define STM32_SERIAL_USE_USART1 FALSE
#define STM32_SERIAL_USE_USART2 TRUE
#define STM32_SERIAL_USE_USART3 FALSE
#define STM32_SERIAL_USE_UART4 FALSE
#define STM32_SERIAL_USE_UART5 FALSE
#define STM32_SERIAL_USE_USART6 FALSE
#define STM32_SERIAL_USART1_PRIORITY 12
#define STM32_SERIAL_USART2_PRIORITY 12
#define STM32_SERIAL_USART3_PRIORITY 12
#define STM32_SERIAL_UART4_PRIORITY 12
#define STM32_SERIAL_UART5_PRIORITY 12
#define STM32_SERIAL_USART6_PRIORITY 12
* SPI driver system settings.
#define STM32_SPI_USE_SPI1 FALSE
#define STM32_SPI_USE_SPI2 FALSE
#define STM32_SPI_USE_SPI3 FALSE
#define STM32_SPI_SPI1_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 0)
#define STM32_SPI_SPI1_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 3)
#define STM32_SPI_SPI2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 3)
#define STM32_SPI_SPI2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_SPI_SPI3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 0)
#define STM32_SPI_SPI3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 7)
#define STM32_SPI_SPI1_DMA_PRIORITY 1
#define STM32_SPI_SPI2_DMA_PRIORITY 1
#define STM32_SPI_SPI3_DMA_PRIORITY 1
#define STM32_SPI_SPI1_IRQ_PRIORITY 10
#define STM32_SPI_SPI2_IRQ_PRIORITY 10
#define STM32_SPI_SPI3_IRQ_PRIORITY 10
#define STM32_SPI_DMA_ERROR_HOOK(spip) osalSysHalt("DMA failure")
* ST driver system settings.
#define STM32_ST_IRQ_PRIORITY 8
#define STM32_ST_USE_TIMER 2
* UART driver system settings.
#define STM32_UART_USE_USART1 FALSE
#define STM32_UART_USE_USART2 FALSE
#define STM32_UART_USE_USART3 FALSE
#define STM32_UART_USE_UART4 FALSE
#define STM32_UART_USE_UART5 FALSE
#define STM32_UART_USE_USART6 FALSE
#define STM32_UART_USART1_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 5)
#define STM32_UART_USART1_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 7)
#define STM32_UART_USART2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 5)
#define STM32_UART_USART2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 6)
#define STM32_UART_USART3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 1)
#define STM32_UART_USART3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 3)
#define STM32_UART_UART4_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 2)
#define STM32_UART_UART4_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_UART_UART5_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 0)
#define STM32_UART_UART5_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 7)
#define STM32_UART_USART6_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 2)
#define STM32_UART_USART6_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 7)
#define STM32_UART_USART1_IRQ_PRIORITY 12
#define STM32_UART_USART2_IRQ_PRIORITY 12
#define STM32_UART_USART3_IRQ_PRIORITY 12
#define STM32_UART_UART4_IRQ_PRIORITY 12
#define STM32_UART_UART5_IRQ_PRIORITY 12
#define STM32_UART_USART6_IRQ_PRIORITY 12
#define STM32_UART_USART1_DMA_PRIORITY 0
#define STM32_UART_USART2_DMA_PRIORITY 0
#define STM32_UART_USART3_DMA_PRIORITY 0
#define STM32_UART_UART4_DMA_PRIORITY 0
#define STM32_UART_UART5_DMA_PRIORITY 0
#define STM32_UART_USART6_DMA_PRIORITY 0
#define STM32_UART_DMA_ERROR_HOOK(uartp) osalSysHalt("DMA failure")
* USB driver system settings.
#define STM32_USB_USE_OTG1 FALSE
#define STM32_USB_USE_OTG2 FALSE
#define STM32_USB_OTG1_IRQ_PRIORITY 14
#define STM32_USB_OTG2_IRQ_PRIORITY 14
#define STM32_USB_OTG1_RX_FIFO_SIZE 512
#define STM32_USB_OTG2_RX_FIFO_SIZE 1024
#define STM32_USB_OTG_THREAD_PRIO LOWPRIO
#define STM32_USB_OTG_THREAD_STACK_SIZE 128
#define STM32_USB_OTGFIFO_FILL_BASEPRI 0
* WDG driver system settings.
#define STM32_WDG_USE_IWDG FALSE
#endif /* _MCUCONF_H_ */[/spoil]
