PULL-UP Input Topic is solved
duracell
Has thanked: 4 times
PULL-UP Input
Post by duracell »
Hi to all,
I configured the GPIOB0 pin as input, the code is the following:
palSetPadMode(GPIOB, 0, PIN_MODE_INPUT(0)|PIN_PUPDR_PULLUP(0));
And in an another board I configured GPIOA7 as output.
palSetPadMode(GPIOA, 7, PAL_STM32_MODE_OUTPUT);
The pin A7 have to generate a square wave, and everythings works fine, but when I connect A7 to B0 the sqare wave is not able to go to 0V again.
The wave no longer oscillates between 3 and 0 but it oscillates between 1 and 3. Why? Where I am wrong?
Thanks to all!
Re: PULL-UP Input
hi,
I don't understand those (0), remove them.
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Re: PULL-UP Input
Post by RoccoMarco »
HI,
as Giovanni says bit masks are wrong. If I understand well you have two different boards. In this case remember to refer them to the same ground.
duracell
Re: PULL-UP Input
Post by duracell »
Hi Giovanni, hi RoccoMarco,
thanks for your reply. I have already connected the grounds.
I agree with you Giovanni that those (0) makes no sense, but if I remove those (0) :
palSetPadMode(GPIOB, 0, PIN_MODE_INPUT | PIN_PUPDR_PULLUP);
The compiler gives me an error.
[spoil]08:52:58 **** Incremental Build of configuration Default for project CAN_Back_Bone ****
make -j4 all
Compiling extlib.c
In file included from ../../chibios161/os/hal/include/pal.h:113:0,
from ../../chibios161/os/hal/include/hal.h:47,
from ./userlib/include/extlib.h:3,
from ./userlib/src/extlib.c:1:
./userlib/src/extlib.c: In function 'gpioconfig':
./userlib/src/extlib.c:101:27: error: 'PIN_MODE_INPUT' undeclared (first use in this function)
../../chibios161/os/hal/ports/STM32/LLD/GPIOv2/pal_lld.h:528:47: note: in definition of macro 'pal_lld_setgroupmode'
_pal_lld_setgroupmode(port, mask << offset, mode)
../../chibios161/os/hal/include/pal.h:527:3: note: in expansion of macro 'palSetGroupMode'
palSetGroupMode(port, PAL_PORT_BIT(pad), 0U, mode)
./userlib/src/extlib.c:101:3: note: in expansion of macro 'palSetPadMode'
./userlib/src/extlib.c:101:27: note: each undeclared identifier is reported only once for each function it appears in
./userlib/src/extlib.c:101:44: error: 'PIN_PUPDR_PULLUP' undeclared (first use in this function)
make: *** [build/obj/extlib.o] Error 1
08:52:59 Build Finished (took 1s.973ms)[/spoil]
I do not understand how to make the PIN 0 as input pin and connect it with the weak pull-up resistor built-in in the MCU.
P.S. the B0 pin is also used by the EXTI peripheral, but i don't think that is a limitation.
RoccoMarco
Re: PULL-UP Input
Indeed you should write,
palSetPadMode(GPIOB, 0, PIN_MODE_INPUT_PULLUP);
Take a look to hal reference manual.
duracell
Re: PULL-UP Input
Post by duracell »
Hi Marco,
The line code you wrote is not accepted by the compiler. it says it is not defined.
I searched the string "PIN_MODE_INPUT_PULLUP" in my chibistudio project and I have been not able to find its declaration.
I am reading the RM, and I see that the pull-up resistor on B0 is activated simply by setting the register GPIOB_PUPDR=0x00000001, but I would like to use the hal and the macros.
Thank you for your help!
duracell
Re: PULL-UP Input
Post by duracell »
P.S you said hal reference manual, I understood the RM of the micro.
wow there is a 964 pages HAL manual! I will take a look right now!
RoccoMarco
Re: PULL-UP Input
What version of chibios are you using?
duracell
Re: PULL-UP Input
Post by duracell »
If I remember well I am using version 3.0.5, where I can read to be sure?
RoccoMarco
Re: PULL-UP Input
C:\ChibiStudio\chibios161\os\hal\include\hal.h
/* Driver constants.                                                         */
 * @brief   ChibiOS/HAL identification macro.
#define _CHIBIOS_HAL_
 * @brief   Stable release flag.
#define CH_HAL_STABLE           1
 * @name    ChibiOS/HAL version identification
 * @brief   HAL version string.
#define HAL_VERSION             "4.0.6"
 * @brief   HAL version major number.
#define CH_HAL_MAJOR            4
 * @brief   HAL version minor number.
#define CH_HAL_MINOR            0
 * @brief   HAL version patch number.
#define CH_HAL_PATCH            6
 * @name    Return codes
#define HAL_SUCCESS             false
#define HAL_FAILED              true
BTW in the same directory take a look to pal.h
 * @name    Pads mode constants
 * @brief   After reset state.
 * @details The state itself is not specified and is architecture dependent,
 *          it is guaranteed to be equal to the after-reset state. It is
 *          usually an input state.
#define PAL_MODE_RESET                  0U
 * @brief   Safe state for <b>unconnected</b> pads.
 *          it may be mapped on @p PAL_MODE_INPUT_PULLUP,
 *          @p PAL_MODE_INPUT_PULLDOWN or @p PAL_MODE_OUTPUT_PUSHPULL for
 *          example.
#define PAL_MODE_UNCONNECTED            1U
 * @brief   Regular input high-Z pad.
#define PAL_MODE_INPUT                  2U
 * @brief   Input pad with weak pull up resistor.
#define PAL_MODE_INPUT_PULLUP           3U
 * @brief   Input pad with weak pull down resistor.
#define PAL_MODE_INPUT_PULLDOWN         4U
 * @brief   Analog input mode.
#define PAL_MODE_INPUT_ANALOG           5U
 * @brief   Push-pull output pad.
#define PAL_MODE_OUTPUT_PUSHPULL        6U
 * @brief   Open-drain output pad.
#define PAL_MODE_OUTPUT_OPENDRAIN       7U
If you cannot find PAL_MODE_INPUT_PULLUP I am afraid you have screwed up something.
