RAM/ROM Usage builder Output :-)
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Post by Tabulous »
Hi All
hope this is can be useful to others.
Wanted an easy way to show how much RAM/ROM was been used. You can do this looking at the *.map file and then work it out, but i wanted something easier.
Another forum user created a python script that does the same, but this needs you to download/install python to run.
So here is my version, this is what you will see after you have built your application, as you can see you know the RAM/ROM usage and how much the heap fill is. All very simple :-) Feel free to download and setup in your chibistudio. See readme for details.
make -j8 all
Linking build/ch.elf
Creating build/ch.hex
Creating build/ch.bin
Creating build/ch.dmp
Creating build/ch.list
text data bss dec hex filename
43776 1432 15304 60512 ec60 build/ch.elf
Heap Fill: 24.6% - 3.93/16KB
RAM usage: 75.4% - 12.07/16KB
ROM usage: 34.2% - 43.80/128KB
Done
binsize.zip
(7.74 KiB) Downloaded 716 times
acr
Re: RAM/ROM Usage builder Output :-)
Post by acr »
in linux it easy to install python, and hard to run .exe
Tabulous
Post by Tabulous »
acr wrote:in linux it easy to install python, and hard to run .exe
In windows its easy to install python too, but i did not want to install a whole package like that just to run a script......
I already have a big bloaty package installed, .Net so might as well use it :-)
raulvalencia2
Post by raulvalencia2 »
another way to know the size of ram used... ?
Simplest way: look in the .map file, it is all in there.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
I just added:
  USE_LDOPT = --print-memory-usage
to the makefile, near the top.
This prints more detailed usage information at the end of linking, which might suffice.
mobyfab
Has thanked: 21 times
Been thanked: 31 times
Post by mobyfab »
my python code it's based on if someone need to modify it: viewtopic.php?f=8&t=2407
