gptPolledDelay() Topic is solved
Jack666
gptPolledDelay()
Post by Jack666 »
Hi everybody.
I'm quite new to ChibiOS and i have a question about gptPolledDelay().
I want to make small delay (between 20 and 200 micro seconds). According to this blog, the best way is to use gptPolledDelay().
I tested my code with an olimex P103 board and ChibiOS 16.1.5. I take the demo code from the chibios example and modified it to test gptPolledDelay().
I set and reset an output and see with an oscilloscope the output.
Here's the code:
static const GPTConfig gpt4cfg = {
    1000000,
    NULL,
    0,
    0
int main(void)
   * System initializations.
   *   RTOS is active.
     gptStart(&GPTD4, &gpt4cfg);
    palSetPadMode(GPIOC, 0, PAL_MODE_OUTPUT_PUSHPULL);
    while (true) {
        palClearPad(GPIOC, 0);
        gptPolledDelay(&GPTD4, 50);
        palSetPad(GPIOC, 0);
        chThdSleepMilliseconds(100);
I expected a delay of 50µs, but all i get is a delay of 600 nanoseconds! Moreover no matter which value i put for the frequency of the timer in GPTConfig, it always give me a 600 nanoseconds delay.
Then i tested with a one shot timer with a callback, instead of the polled delay, and it succesfully give me the delay expected (well more or less some micro seconds).
I need an accurate delay, that's why i need gptPolledDelay().
I must add two things:
- i've tested the code with another board (very similar to olimex one) and same problem.
- Osc configuration is good, chThdSleeMiliseconds() give me the expected result.
Thanks for your help
Jack666
Re: gptPolledDelay()
Post by Jack666 »
Sorry, i've double clicked the "submit" button, and created two threads. Oups...
It is a known bug: https://sourceforge.net/p/chibios/bugs/775/
Already fixed in repository, will be fixed in next release.
Jack666
Post by Jack666 »
Thank you!
