HAL - STM32F030 TIM attribute errors Topic is solved
thor.thau
Post by thor.thau »
I am implementing some PWM outputs on a STM32F030x8 microcontroller. I noticed some errors in channel count for TIM16 and TIM17 but ended up updating everything in the "TIM attributes" section for STM32F030x6, STM32F030x8 and STM32F030xC.
ChibiOS: 16.1.5
SVN: branches/stable_16.1.x@9852
diff --git a/os/hal/ports/STM32/STM32F0xx/stm32_registry.h b/os/hal/ports/STM32/STM32F0xx/stm32_registry.h
index bf7a271..663221c 100644
--- a/os/hal/ports/STM32/STM32F0xx/stm32_registry.h
+++ b/os/hal/ports/STM32/STM32F0xx/stm32_registry.h
@@ -1306,30 +1306,45 @@
 #define STM32_TIM3_IS_32BITS                FALSE
 #define STM32_TIM3_CHANNELS                 4
+#if defined(STM32F030x8) || defined(STM32F030xC)
 #define STM32_HAS_TIM6                      TRUE
+#else
+#define STM32_HAS_TIM6                      FALSE
+#endif
 #define STM32_TIM6_IS_32BITS                FALSE
 #define STM32_TIM6_CHANNELS                 0
+#if defined(STM32F030xC)
+#define STM32_HAS_TIM7                      TRUE
+else
+#define STM32_HAS_TIM7                      FALSE
+#endif
+#define STM32_TIM7_IS_32BITS                FALSE
+#define STM32_TIM7_CHANNELS                 0
 #define STM32_HAS_TIM14                     TRUE
 #define STM32_TIM14_IS_32BITS               FALSE
 #define STM32_TIM14_CHANNELS                1
 #define STM32_HAS_TIM15                     TRUE
+#else
+#define STM32_HAS_TIM15                     FALSE
+#endif
 #define STM32_TIM15_IS_32BITS               FALSE
 #define STM32_TIM15_CHANNELS                2
 #define STM32_HAS_TIM16                     TRUE
 #define STM32_TIM16_IS_32BITS               FALSE
-#define STM32_TIM16_CHANNELS                2
+#define STM32_TIM16_CHANNELS                1
 #define STM32_HAS_TIM17                     TRUE
 #define STM32_TIM17_IS_32BITS               FALSE
-#define STM32_TIM17_CHANNELS                2
+#define STM32_TIM17_CHANNELS                1
 #define STM32_HAS_TIM2                      FALSE
 #define STM32_HAS_TIM4                      FALSE
 #define STM32_HAS_TIM5                      FALSE
-#define STM32_HAS_TIM7                      FALSE
 #define STM32_HAS_TIM8                      FALSE
 #define STM32_HAS_TIM9                      FALSE
 #define STM32_HAS_TIM10                     FALSE
stm32_registry.patch.zip
(528 Bytes) Downloaded 447 times
thor.thau
Re: HAL - STM32F030 TIM attribute errors
Post by thor.thau »
For easy verification of the changes check the datasheet in section 2 table 2 or section 3.11 table 5.
STM32F030x4/6/8/C datasheet
Thanks, we are not ignoring this bug, it is just in queue :)
thor.thau
Post by thor.thau »
I do not think you are ignoring this bug. Maybe given it a very low priority because my guess is that it doesn't affect any drivers in the current HAL.
I see it as an error on my part not including what documentation I based my changes on in the initial bug report.
Change committed in trunk, thanks.
thor.thau
Post by thor.thau »
You forgot a part of the change. Selecting MCU type STM32F030xC will fail because STM32_HAS_TIM7 is then redefined.
ChibiOS: 16.1.6
SVN: branches/stable_16.1.x@10005
index 1c9688664..d75faee03 100644
@@ -247,7 +247,6 @@
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Post by RoccoMarco »
Fixed as bug #809
