dbg_panic_msg notes chThdSleepS
kb1gtt
Has thanked: 11 times
Been thanked: 2 times
Post by kb1gtt »
I have a project, which was working, I made some small changes, and it now appears to be jumping into the weeds. My changes were around main.c line 417, and it now fails between lines 444 and 445 on it's first scan through main.c. When I suspend it, I see it's in chSysHalt with a dbg_panic_msg. I see the stack has unused space for all threads. When I try to F5 step into code, to get beyond line 444, it appears to jump around semi-erratically as it would do if I had code optimization turned on. So I'm having trouble getting down to the exact cause of the dbg panic. How do I find what is causing the panic?
main.c snippet and other general information below.
444 gdispFillStringBox(2, 71, 95, 12, "P1 Potable Pump",  gdispOpenFont("DejaVu*"), Black, White, justifyLeft);
445 gdispFillStringBox(2, 83, 40, 12, "Target",  gdispOpenFont("DejaVu*"), Black, White, justifyLeft);
dbg_panic_msg --> chThdSleepS
dbg_isr_cnt --> not within ISR
dbg_lock_cnt --> within lock
This is chibios 3.0.1, with uGFX, on a STM32F429 compiled by Chibi Studio GCC 4.9. My starting point was found as a demo from uGFX, which included Chibios. I have most dbg features enabled in chconf.h
#define CH_DBG_STATISTICS                   TRUE
#define CH_DBG_SYSTEM_STATE_CHECK           TRUE
#define CH_DBG_ENABLE_CHECKS                TRUE
#define CH_DBG_ENABLE_ASSERTS               TRUE
#define CH_DBG_ENABLE_TRACE                 TRUE
#define CH_DBG_ENABLE_STACK_CHECK           TRUE
#define CH_DBG_FILL_THREADS                 TRUE
#define CH_DBG_THREADS_PROFILING            FALSE
My make file does it like this, not the -ggdb -O0 -g3
arm-none-eabi-gcc -c -ggdb -O0 -g3 -mcpu=cortex-m4 -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -fomit-frame-pointer -Wall -Wextra -Wstrict-prototypes -fverbose-asm -MMD -MP -MF .build/dep/fakethumbfile.o.d -I. -Iugfx -Iugfx/3rdparty/tinygl-0.4-ugfx/include -Iugfx/boards/base/STM32F429i-Discovery -Iugfx/drivers/gdisp/STM32LTDC -Ichibios_3.0.1/os/common/ports/ARMCMx/devices/STM32F4xx -Ichibios_3.0.1/os/ext/CMSIS/include -Ichibios_3.0.1/os/ext/CMSIS/ST -Ichibios_3.0.1/os/rt/include -Ichibios_3.0.1/os/rt/ports/ARMCMx -Ichibios_3.0.1/os/rt/ports/ARMCMx/compilers/GCC -Ichibios_3.0.1/os/hal/osal/rt -Ichibios_3.0.1/os/hal/include -Ichibios_3.0.1/os/hal/ports/common/ARMCMx -Ichibios_3.0.1/os/hal/ports/STM32/STM32F4xx -Ichibios_3.0.1/os/hal/ports/STM32/LLD -Ichibios_3.0.1/os/hal/ports/STM32/LLD/DACv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/GPIOv2 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/I2Cv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/OTGv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/RTCv2 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/SPIv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/TIMv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/USARTv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/FSMCv1 -Ichibios_3.0.1/os/hal/boards/ST_STM32F429I_DISCOVERY -Ichibios_3.0.1/os/hal/lib/streams/ -Ichibios_3.0.1/os/various -DGFX_USE_OS_CHIBIOS=TRUE -DGFX_USE_OS_CHIBIOS=TRUE -DCORTEX_USE_FPU=TRUE -DUSE_FPU=hard -DTHUMB_PRESENT -DTHUMB_NO_INTERWORKING -mthumb -DTHUMB fakethumbfile.c -o .build/obj/fakethumbfile.o
Re: dbg_panic_msg notes chThdSleepS
You need the complete stack trace while in the halt function.
kb1gtt
Post by kb1gtt »
Do you mean the "trace buffer" tab? I'm not sure I follow how to complete the stack trace. Here's my trace buffer, but I don't see much related to stack in that dialog.
The stack trace is the stack of function calls you can see in the Debug window (upper left in your image).
kb1gtt
Post by kb1gtt »
Ah, there we have it, I see under the thread one was main.c, which was a call for chThdSleepMicroseconds which was set with 0. I changed it such that the min is 1, and now it's working again.
Thanks for the help.
