dbg_panic_msg notes chThdSleepS
Posted: Tue Oct 25, 2016 10:14 pm
I have a project, which was working, I made some small changes, and it now appears to be jumping into the weeds. My changes were around main.c line 417, and it now fails between lines 444 and 445 on it's first scan through main.c. When I suspend it, I see it's in chSysHalt with a dbg_panic_msg. I see the stack has unused space for all threads. When I try to F5 step into code, to get beyond line 444, it appears to jump around semi-erratically as it would do if I had code optimization turned on. So I'm having trouble getting down to the exact cause of the dbg panic. How do I find what is causing the panic?
main.c snippet and other general information below.
dbg_panic_msg --> chThdSleepS
dbg_isr_cnt --> not within ISR
dbg_lock_cnt --> within lock
This is chibios 3.0.1, with uGFX, on a STM32F429 compiled by Chibi Studio GCC 4.9. My starting point was found as a demo from uGFX, which included Chibios. I have most dbg features enabled in chconf.h
My make file does it like this, not the -ggdb -O0 -g3
444 gdispFillStringBox(2, 71, 95, 12, "P1 Potable Pump", gdispOpenFont("DejaVu*"), Black, White, justifyLeft);
445 gdispFillStringBox(2, 83, 40, 12, "Target", gdispOpenFont("DejaVu*"), Black, White, justifyLeft);dbg_panic_msg --> chThdSleepS
#define CH_DBG_STATISTICS TRUE
#define CH_DBG_SYSTEM_STATE_CHECK TRUE
#define CH_DBG_ENABLE_CHECKS TRUE
#define CH_DBG_ENABLE_ASSERTS TRUE
#define CH_DBG_ENABLE_TRACE TRUE
#define CH_DBG_ENABLE_STACK_CHECK TRUE
#define CH_DBG_FILL_THREADS TRUE
#define CH_DBG_THREADS_PROFILING FALSE
arm-none-eabi-gcc -c -ggdb -O0 -g3 -mcpu=cortex-m4 -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -fomit-frame-pointer -Wall -Wextra -Wstrict-prototypes -fverbose-asm -MMD -MP -MF .build/dep/fakethumbfile.o.d -I. -Iugfx -Iugfx/3rdparty/tinygl-0.4-ugfx/include -Iugfx/boards/base/STM32F429i-Discovery -Iugfx/drivers/gdisp/STM32LTDC -Ichibios_3.0.1/os/common/ports/ARMCMx/devices/STM32F4xx -Ichibios_3.0.1/os/ext/CMSIS/include -Ichibios_3.0.1/os/ext/CMSIS/ST -Ichibios_3.0.1/os/rt/include -Ichibios_3.0.1/os/rt/ports/ARMCMx -Ichibios_3.0.1/os/rt/ports/ARMCMx/compilers/GCC -Ichibios_3.0.1/os/hal/osal/rt -Ichibios_3.0.1/os/hal/include -Ichibios_3.0.1/os/hal/ports/common/ARMCMx -Ichibios_3.0.1/os/hal/ports/STM32/STM32F4xx -Ichibios_3.0.1/os/hal/ports/STM32/LLD -Ichibios_3.0.1/os/hal/ports/STM32/LLD/DACv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/GPIOv2 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/I2Cv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/OTGv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/RTCv2 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/SPIv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/TIMv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/USARTv1 -Ichibios_3.0.1/os/hal/ports/STM32/LLD/FSMCv1 -Ichibios_3.0.1/os/hal/boards/ST_STM32F429I_DISCOVERY -Ichibios_3.0.1/os/hal/lib/streams/ -Ichibios_3.0.1/os/various -DGFX_USE_OS_CHIBIOS=TRUE -DGFX_USE_OS_CHIBIOS=TRUE -DCORTEX_USE_FPU=TRUE -DUSE_FPU=hard -DTHUMB_PRESENT -DTHUMB_NO_INTERWORKING -mthumb -DTHUMB fakethumbfile.c -o .build/obj/fakethumbfile.o
