Doubts regarding PWMConfig
ep.hobbyiest
Has thanked: 4 times
Post by ep.hobbyiest »
I m using F401RE.
I want to generate 30Khz pwm freq with two channels based on later selection on which frequency is to operate.
here is my configuration.
static PWMConfig pwmcfg = {
  30000,                                    /* 10kHz PWM clock frequency.   */
  1000,                                    /* Initial PWM period 1S.       */
  pwmpcb,
   {PWM_OUTPUT_ACTIVE_HIGH, pwmc1cb},
   {PWM_OUTPUT_DISABLED, NULL},
  0,
  0
typedef struct {
  uint32_t                  frequency;
  pwmcnt_t                  period;
  pwmcallback_t             callback;
  PWMChannelConfig          channels[PWM_CHANNELS];
} PWMConfig;
uint32_t frequency; is this timer base frequency?
pwmcnt_t period; is this pwm freq?
i gone through documentation, but it is confusing me?
Re: Doubts regarding PWMConfig
Correct, timer frequency and PWM period in cycles.
Note that the frequency must be a value that can be obtained by the timer input clock, APB1 or APB2 depending on the timer, using the 16bits prescaler. Illegal values are caught by an assertion.
ep.hobbyiest
Giovanni wrote:Note that the frequency must be a value that can be obtained by the timer input clock, APB1 or APB2 depending on the timer, using the 16bits prescaler. Illegal values are caught by an assertion.
i gonna generate 40khz frequency on two channels for sine wave. if i m not wrong, then, in callback function i ll update duty cycle.
