I'm a Telematic Engineering Student, I'm using ChibiOS in one of my classes , I'm new to programming in C and I need help so I was wondering if you can
help me.
In a brief way I'm trying to include a library in ChibiOS, is an arduino library for a GLCD and it doesn't have a makefile, so I put the folder where I have the library in the file of the project, and in the makefile I add in the source files the name of the library without the path, in theory that should work, but when I build the project to make sure I'm including the library in the right way it throws me the next error:
"fatal error: u8g.h: No such file or directory"
If anyone can help me it would be a great pleasure.
Include Problem
- RoccoMarco
- Has thanked: 83 times
- Been thanked: 67 times
Re: Include Problem
some time ago I wrote an article about this problem. I think you should read. This would be helpful somehow.
C Library design for embedded applications: tips and hints
Note that your problem is not only related to the inclusion of the library but also to the integration of the library with ChibiOS
Ciao
Ciao
