Producer from ISRs Example / S-Locked Query Topic is solved
alan5
Post by alan5 »
I'd like to implement some form of producer ISR, consumer thread queue and found the following page:
http://www.chibios.org/dokuwiki/doku.ph ... el_mutexes
I'm trying to make sense of the "Producer from ISRs" example.
I was hoping someone would be able to help explain the behaviour of qConsume():
  1. chSysLock() disables interrupts
  2. The mutex is locked
  3. The queue is empty
  4. chCondWaitS() is used to:
    1. free the mutex
    2. wait on the queue to fill
Will the chSysLock() call still be active and blocking interrupts during this wait?
I think my understanding of the "S" system state is lacking - it's possible to sleep in an S state?
Some relevant documentation:
chCondWaitS - http://chibios.sourceforge.net/docs3/rt ... 2ab2c2996c
System States - http://chibios.sourceforge.net/html/con ... tem_states
chSchGoSleepS - http://chibios.sourceforge.net/html/gro ... 19c1ccf986
awygle
Has thanked: 6 times
Been thanked: 4 times
Re: Producer from ISRs Example / S-Locked Query
Post by awygle »
When sleeping in a locked state (using S-class functions), interrupts are re-enabled when the thread is switched out, and disabled again when the thread is switched back in. (More properly, the system lock is released - this may or may not be the same as "interrupts" on all platforms, hence chSysLockFromISR())
If you look at the implementations of most of the non S-class Sleep- and Wait-type functions, internally they are just locking and calling the corresponding S-class version of themselves.
alan5
Post by alan5 »
Thanks for your reply. I had my suspicions about this but was hoping someone could confirm the behaviour.
Presumably then threads which were suspended as a result of normal scheduling, as opposed to the user making a blocking API call are not relocked? Since the chSysLock() call was not made by the user.
Presumably detection for this is if the thread state was "sleeping" or "ready"?
The switch protocol in ChibiOS is:
lock
switch
unlock
The unlock operation is done "on the other side" after the thread switched. It never happens that the system stays with interrupts disabled waiting for something.
