Can some one explain the benefits ?
The down side is it hinders debuging........ variables with ext .lto_priv cant be veiwed in the debugger window
LTO or not LTO that is the question
Re: LTO or not LTO that is the question
The plus should be a greater optimization resulting in more speed and/or lower code size.
You should be able to assess the difference easily.
Giovanni wrote:Hi,
with lto on some globals cant be added to the variable view when debugging. If you disable lto everything works fine.
So for me lto is a hindrance, just like most optimizations are. First thing i do when starting a new project is set -O0.
It is not useful during development for sure. It is not mandatory anyway, our default settings are for "final" phase.
