ChibiStudio 17 does not start
kreyl
Been thanked: 4 times
Post by kreyl »
Hi!
My system: Windows 8.1 64 bit, Java 64 bit
When I try to launch Chibistudio (both using .bat file, or just by running eclipse.exe) I have error window telling "Java was started but returned exit code=13" and a lot of other stuff (I can put it here if this helps). What am I doing wrong?
Meanwhile, I have working toolchain based on Eclipse Mars with GNU ARM Eclipse plugin. I have installed chibios tools plugin from http://www.chibios.org/eclipse/chibistudio
and now eclipse says that chibitools version is 2.4.1.201606282101.
But, how can I use it? Nothing seems changed in Eclipse. If I would have original Chibistudio, I could mine info out there.
Re: ChibiStudio 17 does not start
You need Java 32 bits installed too.
