[BUG] Problem with chMBReset() Topic is solved
We discovered an issue with function chMBReset(), it affects all ChibiOS/RT versions. The problem is triggered by the following sequence:
1) Thread A fetches from an empty mailbox, it goes to sleep on the semaphore "fullsem".
2) Thread B with higher priority posts on the mailbox, A is woken and goes "ready" with message MSG_OK.
3) Thread C with higher priority resets the mailbox using chMBReset(), A is already ready so it does not get the MSG_RESET message.
4) B and C go in sleep making A runnable.
5) A takes the MSG_OK path is chMBFetch() reading garbage from the mailbox that has been reset.
The recommended workaround is to not use chMBReset().
From our analysis fixing this bug would require making mailboxes slower and/or larger, the fix will be to remove chMBReset() from the API. It should not be an issue because it is a marginal functionality.
Re: [BUG] Problem with chMBReset()
Update, I decided for a complete rework of the mailboxes code.
Changes:
1) Mailboxes no more use semaphores but lower-level thread queues.
2) Now resetting a mailbox brings it in a "reset state", all subsequent operations will fail with MSG_RESET. This ensures that no threads can enter the mailbox so it can be safely disposed.
3) The reset state can be exited by calling chMBResumeX(), new API.
4) Everything else works as usual.
The code is in the trunk repository for review, the test suite fails because it has not yet been adapted to handle the reset state, tomorrow I will fix it.
If successful the new implementation will be back-ported to 16.1.x, sorry for holding back releases but this was important.
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
I have tested the new mailboxes implementation, and it fails on some code that worked just before the change.
It fails on the first call to chMBPost in my application :
The issue seems to be that chSysUnlock is called twice.
For the record, it's on a stm32f7, systick mode, but it probably does not matter.
chSysUnlock () at ../../../ChibiOS_next/os/rt/include/chsys.h:389
389       _stats_stop_measure_crit_thd();
(gdb)
_stats_stop_measure_crit_thd () at ../../../ChibiOS_next/os/rt/src/chstats.c:105
105       chTMStopMeasurementX(&ch.kernel_stats.m_crit_thd);
(gdb)
chTMStopMeasurementX (tmp=0x20001628 <ch+168>) at ../../../ChibiOS_next/os/rt/src/chtm.c:129
129       tm_stop(tmp, chSysGetRealtimeCounterX(), ch.tm.offset);
(gdb)
port_rt_get_counter_value () at ../../../ChibiOS_next/os/common/ports/ARMCMx/chcore_v7m.h:708
708       return DWT->CYCCNT;
(gdb)
709     }
(gdb)
tm_stop (tmp=0x20001628 <ch+168>, now=2405613119, offset=40) at ../../../ChibiOS_next/os/rt/src/chtm.c:57
57        tmp->n++;
(gdb)
58        tmp->last = (now - tmp->last) - offset;
(gdb)
59        tmp->cumulative += (rttime_t)tmp->last;
(gdb)
60        if (tmp->last > tmp->worst) {
(gdb)
61          tmp->worst = tmp->last;
(gdb)
63        if (tmp->last < tmp->best) {
(gdb)
66      }
(gdb)
chTMStopMeasurementX (tmp=0x20001628 <ch+168>) at ../../../ChibiOS_next/os/rt/src/chtm.c:130
130     }
(gdb)
_stats_stop_measure_crit_thd () at ../../../ChibiOS_next/os/rt/src/chstats.c:106
106     }
(gdb)
chSysUnlock () at ../../../ChibiOS_next/os/rt/include/chsys.h:395
395       chDbgAssert((ch.rlist.queue.next == (thread_t *)&ch.rlist.queue) ||
(gdb)
chSysHalt (reason=0x8027c48 <__func__.7460> "chSysUnlock") at ../../../ChibiOS_next/os/rt/src/chsys.c:194
194       port_disable();
Alexandre
Thanks for finding, still work in progress but good to know :)
Just tested with the state checker but the test suite passes and the function makes a single call to chSysUnlock().
Are your IRQ priorities in the range 3..15? it could be IRQ code executed within the kernel critical zones.
alex31
Post by alex31 »
Yes, minimum priority is 5 :
grep IRQ_PRIORITY mcuconf.h | sort -n -k 3
#define STM32_I2C_I2C1_IRQ_PRIORITY         5
Tomorrow i will try to write a small example that exhibit the problem.
Thanks
Alexandre
alex31
Post by alex31 »
i have been able to reproduce the error with a simple program which just post in main and fetch in a thread.
All goes fine if both main and thread priorities are equals, but it fails if not :
#include <ch.h>
#include <hal.h>
static msg_t  mbBuf[2];
static MAILBOX_DECL(mb, mbBuf, sizeof(mbBuf)/sizeof(mbBuf[0]));
static THD_WORKING_AREA(waBlinker, 384);        // declaration de la pile du thread blinker
static void blinker (void *arg)                 // fonction d'entrée du thread blinker
  (void)arg;
  msg_t from;
  while (true) {
    chMBFetch (&mb, (msg_t *) &from, TIME_INFINITE);
int  main(void) {
// works OK if prio is NORMALPRIO
  chThdCreateStatic(waBlinker, sizeof(waBlinker), NORMALPRIO+2, &blinker, NULL);
  while (true) {
    chMBPost (&mb, (msg_t) 0, TIME_IMMEDIATE);
    chThdSleepMilliseconds(100);
    palToggleLine (LINE_C00_LED1);
Alexandre
Thanks, I will give it a try.
I fixed A problem in new mailboxes, not sure if it the same you experienced, could you give it a try?
alex31
Post by alex31 »
hello,
problem fixed in the small example and in the real application,
thanks !
Alexandre
