Does Mailbox block other threads?
carldong
Post by carldong »
I tried to use mailbox + memory pool as a FIFO to communicate between threads. Currently, I tested this configuration on the receiving thread:
    chMBFetch(&mb, (msg_t *)p, TIME_INFINITE);
where `p` is actually a pointer to something in a memory pool. However, as I observed, this line seems to block all other threads. I am not sure whether it is expected. It is possible to use `TIME_IMMEDIATE` and then insert a manual delay, but I don't like that solution.
Maybe mailbox is not the best way to do it, but I can't think of other methods for now.
BTW, how should I see whether a certain action will yield the execution to other threads? I know event waiting yields, sleeps also does, but what about other things, like sdPutTimeout and such?
carldong
Re: Does Mailbox block other threads?
Post by carldong »
Ah, stupid me... 10 seconds after I posted this, I noticed that I should pass
(msg_t *) &p
instead of
(msg_t *) p
. Unfortunately `-Werror=all` didn't capture this one...
And indeed this operation yields to other threads. Can I assume anything in ChibiOS that requires waiting will yield to other threads?
Blocking calls always give control to other threads unless you see "Polled" in the function name.
