How to properly activate the analog watchdog Topic is solved
rreignier
Has thanked: 8 times
Been thanked: 4 times
Post by rreignier »
I have tried to use the analog watchdog on a STM32F303K8, so it uses the ADCv3 driver.
I have managed to use it by setting the AWD1EN bit of the CFGR register manually.
Either with :
adcStartConversion(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
ADCD1.adcm->CFGR |= ADC_CFGR_AWD1EN;
Or with a ChibiOS define:
ADCD1.adcm->CFGR |= ADC_CFGR_AWD1_ALL;
So it works but I wonder if there is a nicer way to do it without having to manipulate directly the configuration registers?
A simple example application:
#include "ch.h"
#include "chprintf.h"
static BaseSequentialStream* serial = (BaseSequentialStream*)&SD2;
#define ADC_GRP1_NUM_CHANNELS 2
#define ADC_GRP1_BUF_DEPTH 1
static adcsample_t samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
static void adccallback(ADCDriver* adcp, adcsample_t* buffer, size_t n)
  (void)adcp;
  (void)buffer;
  (void)n;
bool watchdogTriggered = false;
static void adcerrorcallback(ADCDriver *adcp, adcerror_t err)
  if(adcp == &ADCD1 && err == ADC_ERR_AWD1)
    watchdogTriggered = true;
static const ADCConversionGroup adcgrpcfg = {
  TRUE,
  ADC_GRP1_NUM_CHANNELS,
  adccallback,
  adcerrorcallback,
  ADC_CFGR_CONT, /* CFGR */
  ADC_TR(0, 3000), /* TR1 */
    /* SMPR[2] */
    0,
    ADC_SMPR2_SMP_AN11(ADC_SMPR_SMP_601P5) |
      ADC_SMPR2_SMP_AN12(ADC_SMPR_SMP_601P5),
    /* SQR[4]  */
    ADC_SQR1_SQ1_N(ADC_CHANNEL_IN11) | ADC_SQR1_SQ2_N(ADC_CHANNEL_IN12),
    0,
    0,
    0
int main(void)
  // Setting up analog inputs.
  palSetGroupMode(
    GPIOB, PAL_PORT_BIT(0) | PAL_PORT_BIT(1), 0, PAL_MODE_INPUT_ANALOG);
  // Activates the ADC1 driver
  adcStart(&ADCD1, NULL);
  // Activate Serial Driver
  sdStart(&SD2, NULL);
  // Starts an ADC continuous conversion.
  // Activate the analog Watchdog
  //ADCD1.adcm->CFGR |= ADC_CFGR_AWD1_ALL;
  chprintf(serial, "Test program of the analog watchdog.\n");
  while(true)
    chprintf(serial, "IN11 = %u IN12 = %u\n", samples[0], samples[1]);
    if(watchdogTriggered)
      chprintf(serial, "Analog Watchdog Triggered!\n");
      // Handle the error...
      chThdSleepMilliseconds(500);
      // Start the conversion again
      // Activatye the analog watchdog
    chThdSleepMilliseconds(200);
Thanks
rreignier
Re: How to properly activate the analog watchdog
Post by rreignier »
Actually, I have just realized that it is only needed to add the ADC_CFGR_AWD1_ALL flag in the ADCConversionGroup structure!
So something like that do the job:
  TRUE,
  adccallback,
  adcerrorcallback,
  ADC_CFGR_CONT | ADC_CFGR_AWD1_ALL, /* CFGR */
    /* SMPR[2] */
    0,
    /* SQR[4]  */
    0,
    0,
    0
Sorry for the disturbance. But I hope that it could help someone else in the future :)
