We have a project using the STM32F042 and ChibiOS. We have a need to store some configuration data in the processor's flash.
Anyone have an example that writes to flash memory on F0?
Thanks for any help!
Flash write routine for STM32F0
Re: Flash write routine for STM32F0
I use this:
Some things are still a bit "quick and dirty". So you can still see the switch from "we always have 64k flash" to: ask the CPU how much we have. But the flash page size, if it's always 1k... I don't know. It is on the F072 that I use.... The address where you can find "how much flash does this CPU have?" differs from CPU to CPU. And I should probably use a define...
#define MY_FLASH_SIZE (( *(short *)0x1ffff7cc) << 10)
#define FLASH_TOT_SIZE 0x10000 // 64k.
#define FLASH_PAGE_SIZE 0x400 // 1k
#define FLASH_EE_REGION (FLASH_BASE + MY_FLASH_SIZE - FLASH_PAGE_SIZE)
//#define FLASH_EE_REGION (FLASH_BASE + FLASH_TOT_SIZE - FLASH_PAGE_SIZE)
#define flash_wait_nb() while ( FLASH->SR & FLASH_SR_BSY)
#if 0
static void write_to_flash (void *data, int len)
int i;
len++; // Convert to halfwords (= 16 bits, shorts).
len = len >> 1;
for (i=0;i<len;i++)
if (((unsigned short *)FLASH_EE_REGION)[i] != ((unsigned short *)data)[i]) break;
// The data there is already OK.
if (i == len) return;
//myprintf (CONSOLE, "CR: %x ", FLASH->CR);
if (FLASH->CR & FLASH_CR_LOCK) {
//myprintf (CONSOLE, " unlocking ");
FLASH->KEYR = 0x45670123;
FLASH->KEYR = 0xcdef89ab;
for (i=0;i<len;i++)
if (((unsigned short *)FLASH_EE_REGION)[i] != 0xffff) break;
if (i != len) {
//myprintf (CONSOLE, "\r\nNeed an erase... ");
if ( FLASH->SR & FLASH_SR_EOP) {
//pr_hex (CONSOLE, " SR1: ", FLASH->SR);
//my_puts (CONSOLE, "reset EOP ");
FLASH->SR |= FLASH_SR_EOP;
//pr_hex (CONSOLE, " SR2: ", FLASH->SR);
flash_wait_nb ();
FLASH->CR = FLASH_CR_PER;
//myprintf (CONSOLE, " CR1: %x", FLASH->CR);
//myprintf (CONSOLE, " SR3: %x", FLASH->SR);
//myprintf (CONSOLE, " EER: %x", FLASH_EE_REGION);
FLASH->AR = FLASH_EE_REGION;
FLASH->CR |= FLASH_CR_STRT;
//myprintf (CONSOLE, " CR2: %x", FLASH->CR);
flash_wait_nb ();
//myprintf (CONSOLE, "erase done.\r\n");
FLASH->CR &= ~FLASH_CR_PER;
//pr_hex (CONSOLE, " CR: ", FLASH->CR);
//pr_hex (CONSOLE, " SR: ", FLASH->SR);
FLASH->CR |= FLASH_CR_PG;
for (i=0;i<len;i++)
((unsigned short *)FLASH_EE_REGION)[i] = ((unsigned short *)data)[i];
FLASH->CR &= ~FLASH_CR_PG;
FLASH->CR |= FLASH_CR_LOCK;
myprintf (CONSOLE, "Write OK!");
