it would be great to have configuration macro to enable/disable using float arithmetic in base driver's interfaces (BaseSensor and so on) to use EX on small processors with NIL.
Using float optional
- RoccoMarco
- Has thanked: 83 times
- Been thanked: 67 times
Re: Using float optional
Hello there.
I totally missed this post. I'll think about it. The point is that without floating point the whole concept of cooked data would became meaningless.
- RoccoMarco
Does it mean we should implement fixed point algebra? I am not so convinced about that.
At least not use float in raw functions, in this case cooked and float will not be linked
- RoccoMarco
As far as I know float is not used in raw functions...
Do you have seen float in some getRaw?
