I want to transfer data over USB through Serial Over USB mode. Is there any sample code for STM32F4 Discovery board where I can send and receive data using hyper terminal.
Sapan
Example code for Serial Communication over USB
Re: Example code for Serial Communication over USB
The STM32F4 OTG peripheral is not supported yet. The current USB driver is compatible with STM32F103 and STM32L1xx.
Work for F4 support is ongoing.
Giovanni,
I would like to use USB (serial or any other protocol) to configure a board using a STM32F103. I looked through all demos/examples but could not find any code using the USB driver. Do you have a simple example using the USB driver you could share?
Thanks,
Markus
Thanks,
Markus
A demo is located under ./testhal/STM32F1xx/USB_CDC
Giovanni,
thanks for the quick response. Works like a charm on my modded STM32VLDiscovery board.
I replaced the VL uC with a STM32F103RG XL):
--------- snip ----------
ChibiOS/RT Shell
ch> info
Kernel: 2.5.0
Compiler: GCC 4.6.0
Architecture: ARMv7-M
Core Variant: Cortex-M3
Port Info: Advanced kernel mode
Platform: STM32F1 Performance Line eXtra Density
Board: ST STM32VL-DiscoveryXL
Build time: Jun 1 2012 - 17:46:49
ch>
Thanks again,
Markus
ChibiOS/RT Shell
ch> info
Kernel: 2.5.0
Compiler: GCC 4.6.0
ch>
Thanks again,
Markus
