Test suite freeze from shell comandline.
Latest Chibios trunk.
test suite Topic is solved
Re: test suite
I think it does not even start correct? this should be caused by recent changes to the test engine.
Re: test suite
It should be fine now, note that the syntax of the "test" command changed a bit.
Re: test suite
I am testing the STM32F103-NUCLEO64 demo but the test suite does not hang. Do you have enough stack for the test suite in your application? Which compiler are you using? does it crash or it is looping somewhere?
Re: test suite
I do not have hardware now, so I can provide more information on Monday. If I remember, the test stopped at assertion.
Test project in attachment. Compiler GCC 6.3, Chibistudio 19.
Eddie
Eddie
- RT-STM32F103RB-NUCLEO64.ZIP
- (15.08 KiB) Downloaded 570 times
