Chibios github Topic is solved
Eddie
Been thanked: 6 times
Chibios github
Post by Eddie »
who is maintainer of this repository?
https://github.com/ChibiOS/ChibiOS
Changes are not sent for several days into branch master.
Eddie
Eddie
Re: Chibios github
Post by Eddie »
Nobody knows?
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Re: Chibios github
Post by tfAteba »
Hello Eddie,
I think, that the members in charge of the github repository are Utzig for sure and Barthess maybe.
In sourceforge the last update was made 17 hours ago. So that means that the github does not sync any more.
So you can try o contact them in order to resolve this problem.
Thanks
Re: Chibios github
Consider that you can import the subversion repository in your own git repository using a single command if you are in an hurry.
tfAteba
Re: Chibios github
Post by tfAteba »
Hi all,
The problem is solved, Thanks to Utzig :) , the sync is done now so the git repository is updated.
alex31
Has thanked: 57 times
Been thanked: 88 times
Re: Chibios github
Post by alex31 »
It's been a month without github mirror update, seems no more in sync with svn !
Alexandre
Re: Chibios github
You should ask Fabien (Mobyfab) on discord.
alex31
Re: Chibios github
Post by alex31 »
Thanks to Fabien (Mobyfab), the Git mirror has been repaired and is now synced on a daily schedule.
Alexandre
