below is a patch for the STM32 I2Cv1 low-level driver so that it can be used without DMA access. This was required for my use case as there are more imortant things that require DMA and I could afford such non-optimal I2C access.
From 736d3be25b7389b6130e0c372328aa56e2532250 Mon Sep 17 00:00:00 2001
Date: Mon, 12 Jun 2017 17:28:49 +0200
Subject: [PATCH] Introduced I2C without DMA (I2Cv1 only).
os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c | 181 ++++++++++++++++++++++++++++-
os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.h | 30 +++++
2 files changed, 210 insertions(+), 1 deletion(-)
diff --git a/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c b/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c
index 20b8cf8..b2cfb59 100644
--- a/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c
+++ b/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c
@@ -34,6 +34,7 @@
/* Driver local definitions. */
+#if STM32_I2C_USE_DMA
#define I2C1_RX_DMA_CHANNEL \
STM32_DMA_GETCHANNEL(STM32_I2C_I2C1_RX_DMA_STREAM, \
STM32_I2C1_RX_DMA_CHN)
@@ -57,6 +58,7 @@
#define I2C3_TX_DMA_CHANNEL \
STM32_DMA_GETCHANNEL(STM32_I2C_I2C3_TX_DMA_STREAM, \
STM32_I2C3_TX_DMA_CHN)
+#endif /* STM32_I2C_USE_DMA */
/* Driver constants. */
@@ -72,6 +74,20 @@
#define I2C_EV6_MASTER_REC_MODE_SELECTED \
((uint32_t)(((I2C_SR2_MSL | I2C_SR2_BUSY)<< 16) | I2C_SR1_ADDR))
+#define I2C_EV7_MASTER_REC_BYTE_RECEIVED \
+ ((uint32_t)(((I2C_SR2_MSL | I2C_SR2_BUSY)<< 16) | I2C_SR1_RXNE))
+#define I2C_EV7_MASTER_REC_BYTE_RECEIVED_STOP \
+ ((uint32_t)( I2C_SR1_RXNE))
+#define I2C_EV7_2_EV7_3_MASTER_REC_BYTE_QUEUED \
+ ((uint32_t)(((I2C_SR2_MSL | I2C_SR2_BUSY)<< 16) | \
+ I2C_SR1_BTF | I2C_SR1_RXNE))
+#define I2C_EV8_MASTER_BYTE_TRANSMITTING \
+ ((uint32_t)(((I2C_SR2_MSL | I2C_SR2_BUSY | I2C_SR2_TRA)<< 16) | \
+ I2C_SR1_TXE))
#define I2C_EV8_2_MASTER_BYTE_TRANSMITTED \
((uint32_t)(((I2C_SR2_MSL | I2C_SR2_BUSY | I2C_SR2_TRA) << 16) | \
I2C_SR1_BTF | I2C_SR1_TXE))
@@ -128,9 +144,11 @@ static void i2c_lld_abort_operation(I2CDriver *i2cp) {
dp->CR2 = 0;
dp->SR1 = 0;
/* Stops the associated DMA streams.*/
dmaStreamDisable(i2cp->dmatx);
dmaStreamDisable(i2cp->dmarx);
@@ -247,12 +265,13 @@ static void i2c_lld_serve_event_interrupt(I2CDriver *i2cp) {
uint32_t regSR2 = dp->SR2;
uint32_t event = dp->SR1;
/* Interrupts are disabled just before dmaStreamEnable() because there
is no need of interrupts until next transaction begin. All the work is
done by the DMA.*/
switch (I2C_EV_MASK & (event | (regSR2 << 16))) {
case I2C_EV5_MASTER_MODE_SELECT:
- if ((i2cp->addr >> 8) > 0) {
+ if ((i2cp->addr >> 8) > 0) {
/* 10-bit address: 1 1 1 1 0 X X R/W */
dp->DR = 0xF0 | (0x6 & (i2cp->addr >> 8)) | (0x1 & i2cp->addr);
} else {
@@ -292,8 +311,125 @@ static void i2c_lld_serve_event_interrupt(I2CDriver *i2cp) {
/* Clear ADDR flag. */
if (event & (I2C_SR1_ADDR | I2C_SR1_ADD10))
(void)dp->SR2;
+#else
+ switch (I2C_EV_MASK & (event | (regSR2 << 16))) {
+ case I2C_EV5_MASTER_MODE_SELECT:
+ dp->CR2 |= I2C_CR2_ITBUFEN;
+ dp->DR = i2cp->addr;
+ break;
+ case I2C_EV6_MASTER_TRA_MODE_SELECTED:
+ (void)dp->SR2; // clear ADDR flag
+ /* EV8_1 */
+ dp->DR = *(i2cp->txbuf);
+ ++i2cp->txbuf;
+ --i2cp->txbytes;
+ /* if N == 1, skip the I2C_EV8_MASTER_BYTE_TRANSMITTING event
+ * but enter I2C_EV8_2_MASTER_BYTE_TRANSMITTED next */
+ if (i2cp->txbytes == 0) {
+ dp->CR2 &= ~I2C_CR2_ITBUFEN;
+ break;
+ case I2C_EV6_MASTER_REC_MODE_SELECTED:
+ switch (i2cp->rxbytes) {
+ case 1:
+ dp->CR1 &= ~I2C_CR1_ACK;
+ dp->CR1 |= I2C_CR1_STOP;
+ break;
+ case 2:
+ /* EV6_1 */
+ dp->CR1 |= I2C_CR1_POS;
+ break;
+ case 3: /* N == 3 is a very special case, since EV7 is completely skipped */
+ /* Disable the I2C_EV7_MASTER_REC_BYTE_RECEIVED event
+ * but enter I2C_EV7_MASTER_REC_BYTE_RECEIVED_STOP next */
+ break;
+ default: /* N > 2 */
+ break;
+ break;
+ case I2C_EV7_MASTER_REC_BYTE_RECEIVED:
+ if (i2cp->rxbytes > 3) {
+ *(i2cp->rxbuf) = dp->DR;
+ ++i2cp->rxbuf;
+ --i2cp->rxbytes;
+ if (i2cp->rxbytes == 3) {
+ /* Disable this event for DataN-2, but force into event
+ * I2C_EV7_2_EV7_3_MASTER_REC_BYTE_RECEIVED_QUEUED by not reading dp->DR. */
+ break;
+ case I2C_EV7_MASTER_REC_BYTE_RECEIVED_STOP:
+ osalDbgAssert(i2cp->rxbytes == 1, "more than 1 byte to be received");
+ --i2cp->rxbytes;
+ dp->CR2 &= ~(I2C_CR2_ITEVTEN | I2C_CR2_ITBUFEN);
+ _i2c_wakeup_isr(i2cp);
+ break;
+ case I2C_EV7_2_EV7_3_MASTER_REC_BYTE_QUEUED:
+ /* EV7_2 (N > 2) */
+ ++i2cp->rxbuf;
+ ++i2cp->rxbuf;
+ i2cp->rxbytes -= 2;
+ /* enable I2C_EV7_MASTER_REC_BYTE_RECEIVED_STOP event */
+ } else {
+ /* EV7_3 (N == 2) */
+ ++i2cp->rxbuf;
+ dp->CR1 &= ~I2C_CR1_POS;
+ break;
+ case I2C_EV8_MASTER_BYTE_TRANSMITTING:
+ ++i2cp->txbuf;
+ --i2cp->txbytes;
+ /* if this was the last byte, ensure that this event is not entered again */
+ break;
+ case I2C_EV8_2_MASTER_BYTE_TRANSMITTED:
+ if (i2cp->rxbytes > 0) {
+ /* start "read after write" operation (LSB of address = 1 => read) */
+ i2cp->addr |= 0x01;
+ dp->CR1 |= I2C_CR1_START | I2C_CR1_ACK;
+ } else {
+ break;
+ default:
+ osalDbgAssert(i2cp->rxbytes != 1, "more than 1 byte to be received");
+ break;
* @brief DMA RX end IRQ handler.
@@ -347,6 +483,7 @@ static void i2c_lld_serve_tx_end_irq(I2CDriver *i2cp, uint32_t flags) {
of R/W transaction itself.*/
dp->CR2 |= I2C_CR2_ITEVTEN;
* @brief I2C error handler.
@@ -358,9 +495,11 @@ static void i2c_lld_serve_tx_end_irq(I2CDriver *i2cp, uint32_t flags) {
static void i2c_lld_serve_error_interrupt(I2CDriver *i2cp, uint16_t sr) {
/* Clears interrupt flags just to be safe.*/
i2cp->errors = I2C_NO_ERROR;
@@ -506,24 +645,30 @@ void i2c_lld_init(void) {
i2cObjectInit(&I2CD1);
I2CD1.thread = NULL;
I2CD1.i2c = I2C1;
I2CD1.dmarx = STM32_DMA_STREAM(STM32_I2C_I2C1_RX_DMA_STREAM);
I2CD1.dmatx = STM32_DMA_STREAM(STM32_I2C_I2C1_TX_DMA_STREAM);
#endif /* STM32_I2C_USE_I2C1 */
#if STM32_I2C_USE_I2C2
i2cObjectInit(&I2CD2);
I2CD2.thread = NULL;
I2CD2.i2c = I2C2;
I2CD2.dmarx = STM32_DMA_STREAM(STM32_I2C_I2C2_RX_DMA_STREAM);
I2CD2.dmatx = STM32_DMA_STREAM(STM32_I2C_I2C2_TX_DMA_STREAM);
#endif /* STM32_I2C_USE_I2C2 */
#if STM32_I2C_USE_I2C3
i2cObjectInit(&I2CD3);
I2CD3.thread = NULL;
I2CD3.i2c = I2C3;
I2CD3.dmarx = STM32_DMA_STREAM(STM32_I2C_I2C3_RX_DMA_STREAM);
I2CD3.dmatx = STM32_DMA_STREAM(STM32_I2C_I2C3_TX_DMA_STREAM);
#endif /* STM32_I2C_USE_I2C3 */
@@ -540,6 +685,7 @@ void i2c_lld_start(I2CDriver *i2cp) {
/* If in stopped state then enables the I2C and DMA clocks.*/
if (i2cp->state == I2C_STOP) {
i2cp->txdmamode = STM32_DMA_CR_PSIZE_BYTE | STM32_DMA_CR_MSIZE_BYTE |
STM32_DMA_CR_MINC | STM32_DMA_CR_DMEIE |
STM32_DMA_CR_TEIE | STM32_DMA_CR_TCIE |
@@ -548,9 +694,11 @@ void i2c_lld_start(I2CDriver *i2cp) {
STM32_DMA_CR_DIR_P2M;
#if STM32_I2C_USE_I2C1
if (&I2CD1 == i2cp) {
bool b;
rccResetI2C1();
@@ -564,19 +712,23 @@ void i2c_lld_start(I2CDriver *i2cp) {
(stm32_dmaisr_t)i2c_lld_serve_tx_end_irq,
(void *)i2cp);
osalDbgAssert(!b, "stream already allocated");
rccEnableI2C1(FALSE);
nvicEnableVector(I2C1_EV_IRQn, STM32_I2C_I2C1_IRQ_PRIORITY);
nvicEnableVector(I2C1_ER_IRQn, STM32_I2C_I2C1_IRQ_PRIORITY);
i2cp->rxdmamode |= STM32_DMA_CR_CHSEL(I2C1_RX_DMA_CHANNEL) |
STM32_DMA_CR_PL(STM32_I2C_I2C1_DMA_PRIORITY);
i2cp->txdmamode |= STM32_DMA_CR_CHSEL(I2C1_TX_DMA_CHANNEL) |
if (&I2CD2 == i2cp) {
bool b;
rccResetI2C2();
@@ -590,19 +742,23 @@ void i2c_lld_start(I2CDriver *i2cp) {
(void *)i2cp);
rccEnableI2C2(FALSE);
nvicEnableVector(I2C2_EV_IRQn, STM32_I2C_I2C2_IRQ_PRIORITY);
nvicEnableVector(I2C2_ER_IRQn, STM32_I2C_I2C2_IRQ_PRIORITY);
i2cp->rxdmamode |= STM32_DMA_CR_CHSEL(I2C2_RX_DMA_CHANNEL) |
STM32_DMA_CR_PL(STM32_I2C_I2C2_DMA_PRIORITY);
i2cp->txdmamode |= STM32_DMA_CR_CHSEL(I2C2_TX_DMA_CHANNEL) |
if (&I2CD3 == i2cp) {
bool b;
rccResetI2C3();
@@ -616,26 +772,35 @@ void i2c_lld_start(I2CDriver *i2cp) {
(void *)i2cp);
rccEnableI2C3(FALSE);
nvicEnableVector(I2C3_EV_IRQn, STM32_I2C_I2C3_IRQ_PRIORITY);
nvicEnableVector(I2C3_ER_IRQn, STM32_I2C_I2C3_IRQ_PRIORITY);
i2cp->rxdmamode |= STM32_DMA_CR_CHSEL(I2C3_RX_DMA_CHANNEL) |
STM32_DMA_CR_PL(STM32_I2C_I2C3_DMA_PRIORITY);
i2cp->txdmamode |= STM32_DMA_CR_CHSEL(I2C3_TX_DMA_CHANNEL) |
/* I2C registers pointed by the DMA.*/
dmaStreamSetPeripheral(i2cp->dmarx, &dp->DR);
dmaStreamSetPeripheral(i2cp->dmatx, &dp->DR);
/* Reset i2c peripheral.*/
dp->CR1 = I2C_CR1_SWRST;
dp->CR1 = 0;
dp->CR2 = I2C_CR2_ITERREN | I2C_CR2_DMAEN;
+#else
+ dp->CR2 = I2C_CR2_ITERREN;
/* Setup I2C parameters.*/
i2c_lld_set_clock(i2cp);
@@ -659,8 +824,10 @@ void i2c_lld_stop(I2CDriver *i2cp) {
/* I2C disable.*/
i2c_lld_abort_operation(i2cp);
dmaStreamRelease(i2cp->dmatx);
dmaStreamRelease(i2cp->dmarx);
@@ -730,10 +897,15 @@ msg_t i2c_lld_master_receive_timeout(I2CDriver *i2cp, i2caddr_t addr,
/* Releases the lock from high level driver.*/
osalSysUnlock();
/* RX DMA setup.*/
dmaStreamSetMode(i2cp->dmarx, i2cp->rxdmamode);
dmaStreamSetMemory0(i2cp->dmarx, rxbuf);
dmaStreamSetTransactionSize(i2cp->dmarx, rxbytes);
+#else
+ i2cp->rxbuf = rxbuf;
+ i2cp->rxbytes = rxbytes;
/* Calculating the time window for the timeout on the busy bus condition.*/
start = osalOsGetSystemTimeX();
@@ -810,6 +982,7 @@ msg_t i2c_lld_master_transmit_timeout(I2CDriver *i2cp, i2caddr_t addr,
osalSysUnlock();
/* TX DMA setup.*/
dmaStreamSetMode(i2cp->dmatx, i2cp->txdmamode);
dmaStreamSetMemory0(i2cp->dmatx, txbuf);
@@ -819,6 +992,12 @@ msg_t i2c_lld_master_transmit_timeout(I2CDriver *i2cp, i2caddr_t addr,
+#else
+ i2cp->txbuf = txbuf;
+ i2cp->txbytes = txbytes;
diff --git a/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.h b/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.h
index a812ceb..127c708 100644
--- a/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.h
+++ b/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.h
@@ -76,6 +76,15 @@
+ * @brief I2C data transfer use dma switch.
+ * @details If set to @p TRUE the support for I2C DMA is included.
+ * @note The default is @p FALSE.
+#if !defined(STM32_I2C_USE_DMA) || defined(__DOXYGEN__)
+#define STM32_I2C_USE_DMA TRUE
+#endif
* @brief I2C timeout on busy condition in milliseconds.
#if !defined(STM32_I2C_BUSY_TIMEOUT) || defined(__DOXYGEN__)
@@ -249,6 +258,7 @@
#error "Invalid IRQ priority assigned to I2C3"
#if STM32_I2C_USE_I2C1 && \
!STM32_DMA_IS_VALID_PRIORITY(STM32_I2C_I2C1_DMA_PRIORITY)
#error "Invalid DMA priority assigned to I2C1"
@@ -319,6 +329,7 @@
#if !defined(STM32_DMA_REQUIRED)
#define STM32_DMA_REQUIRED
/* Check clock range. */
#if defined(STM32F4XX)
@@ -436,6 +447,7 @@ struct I2CDriver {
* @brief Current slave address without R/W bit.
i2caddr_t addr;
* @brief RX DMA mode bit mask.
@@ -452,6 +464,24 @@ struct I2CDriver {
* @brief Transmit DMA channel.
const stm32_dma_stream_t *dmatx;
+#else
+ * @brief Receive buffer.
+ uint8_t *rxbuf;
+ * @brief Receive buffer size.
+ size_t rxbytes;
+ * @brief Transmit buffer.
+ const uint8_t *txbuf;
+ * @brief Transmit buffer size.
+ size_t txbytes;
* @brief Pointer to the I2Cx registers block.
2.7.4
This modification requires an additional macro in the mcuconf.h file for the I2C driver system settings:
#define STM32_I2C_USE_DMA FALSEMaybe someone other than me finds this helpful
-Thomas
