Thread function starting in locked state
jschall
Post by jschall »
On STM32, I'm creating a thread like so:
void worker_thread_init(/*...*/) {
    void* working_area = chCoreAllocAligned(THD_WORKING_AREA_SIZE(stack_size), PORT_WORKING_AREA_ALIGN);
    if (!working_area) {
        return;
    chDbgCheck(ch.dbg.lock_cnt == 0);
    worker_thread->thread = chThdCreateStatic(working_area, THD_WORKING_AREA_SIZE(stack_size), prio, worker_thread_func, worker_thread);
    chThdSleep(TIME_INFINITE);
And I've put this debug check at the top of the thread function:
static THD_FUNCTION(worker_thread_func, arg) {
The debug check in worker_thread_func fails. The one in worker_thread_init does not.
I've banged my head against this for several hours now. Any idea what's going on?
Re: Thread function starting in locked state
Which ChibiOS version? are you using the provided makefiles in your project?
jschall
Post by jschall »
The chibios version is 17.6.3.
The Makefile is modified from the provided Makefile, but rules.mk remains almost exactly the same.
jschall
Post by jschall »
I switched to using the rules.mk provided by ChibiOS, which had a small change. The issue still occurs.
-ASFLAGS   = $(MCFLAGS) -Wa,-amhls=$(LSTDIR)/$(notdir $(<:.s=.lst)) $(ADEFS)
-ASXFLAGS  = $(MCFLAGS) -Wa,-amhls=$(LSTDIR)/$(notdir $(<:.S=.lst)) $(ADEFS)
+ASFLAGS   = $(MCFLAGS) $(OPT) -Wa,-amhls=$(LSTDIR)/$(notdir $(<:.s=.lst)) $(ADEFS)
+ASXFLAGS  = $(MCFLAGS) $(OPT) -Wa,-amhls=$(LSTDIR)/$(notdir $(<:.S=.lst)) $(ADEFS)
I suspect that your .S files are not recompiled when you change chconfh, that could explain the behavior because the thread trampoline code would not decrement that counter.
               .thumb_func
                .globl  _port_thread_start
_port_thread_start:
#if CH_DBG_SYSTEM_STATE_CHECK
                bl      _dbg_check_unlock
#if CH_DBG_STATISTICS
                bl      _stats_stop_measure_crit_thd
#if CORTEX_SIMPLIFIED_PRIORITY
                cpsie   i
#else
                movs    r3, #0              /* CORTEX_BASEPRI_DISABLED */
                msr     BASEPRI, r3
                mov     r0, r5
                blx     r4
#if defined(_CHIBIOS_RT_CONF_)
                movs    r0, #0              /* MSG_OK */
                bl      chThdExit
#if defined(_CHIBIOS_NIL_CONF_)
                mov     r3, #0
                bl      chSysHalt
Note the call to _dbg_check_unlock(), it is within a condition, it is where the counter is decremented. This is why I think to a build issue.
jschall
Post by jschall »
I've been doing completely clean builds - in which the build directory was deleted. I'll clean again and do a search for files that don't belong.
Look into the generated listing if that "bl" is actually compiled.
jschall
Post by jschall »
I think I know what it is. I was using UDEFS += -D... to enable the checks. I'll figure it out and fix it.
jschall
Post by jschall »
Thanks! This was a really tough one to debug.
How about a check like this?
ifneq ($(sort $(filter -DCH_DBG%,$(DEFS))),$(sort $(filter -DCH_DBG%,$(ADEFS))))
  $(error -DCH_DBG flags differ between DEFS and ADEFS)
endif
You could add that to the makefile, I don't think that rules.mk should be "aware" of upper layers.
