Ext driver example
Ext driver example
Hello Folks,
Could someone provide a very bare example, how to use the EXT driver? I didn't had any problems at all with other drivers like SPI, PAL, ADC etc, when I read the documentation. But I really don't have any clue how to use the EXT driver to use external interrupts, for example for a touchpad.
Thanks
Re: Ext driver example
There are examples under ./testhal.
ooh! Thats pretty useful.
Thanks for the tip, sir!
I've one more question:
How about arguments etc? Is it possible to pass a pointer to a big buffer to the callback function? I'd need a buffer of 2048 bytes size there. I guess it's not that good when I write unsigned char buffer[2048]; into the callback function.
How to make this work the right way?
In general large buffers should never be automatic variables. If you make it static you don't need to pass a pointer, you already know where it is.
Can I go with another question?
I use the EXT driver to fire an interrupt when my touchpad controller puts PEN_IRQ low. This works great. I can toggle an LED by pressing the touchpad ;-)
Now, of course, I want to use the ISR to read out the X and Y coordinates. Now: When I make:
static void touchIRQ(EXTDriver *extp, expchannel_t channel) {
    (void)extp;
    (void)channel;
    lcdDrawPixel(tpReadY(), tpReadY(), Green);
I can compile, and load the .elf. When I run, nothing works :D It just hangs there and not even anything from the main gets executed. When I comment the lcdDrawPixel line out, it works. I could figure out that the problem is the calling of tpReadX() and tpReadY() causes this error.
This is my tpReadX():
static uint16_t tpReadRealX(void) {
   uint32_t results = 0;
   uint16_t i, x;
   for(i=0; i<CONVERSIONS; i++) {
      readX();
      results += readX();
        // get from 0 to 2048   to  0 to LCD "length"
   x = (((lcdGetHeight()-1) * (results/CONVERSIONS)) / 2048);
   return x;
uint16_t tpReadX(void) {
        // calibrate
   return cal.xm * tpReadRealX() + cal.xn;
I also tried:
    (void)extp;
    (void)channel;
void foo(void) {
    uint16_t x, y;
    x = tpReadX();
    y = tpReadY();
This gave the same result.
Any ideas?
Are you OK with using complex graphic primitives from ISRs?
BTW, moving to the support forum in order to reduce noise in the development forum.
Thanks for the moving, I'll post similar question to there from now on (if i am allowed to ask more ;-))
What would be the propper way to do that then? I never worked with an RTOS. I come from the AVR side.
I guess I can use external interrupts from the PEN_IRQ signal from the touchpad controller somehow to read out the actual coordinates?
You are welcome to ask questions :-)
If you need to perform an "heavy" operation in response of an external event (the callback) usually you wake up a thread to do the work out of ISR context.
There is an article in the documentation about various ways to wakeup a thread:
http://www.chibios.org/dokuwiki/doku.ph ... tos:wakeup
the right one depends on what you want to achieve. Additionally you may use a mailbox if you need to send messages from the ISR to the thread.
Giovanni wrote:You are welcome to ask questions :-)
That's nice to hear. I always try to not ask too stupid questions :D
Thanks for the link. This looks like what I need. I did the following:
static Thread *tpThread = NULL;
void mythread(void *p) {
    while (TRUE) {
        palTogglePad(GPIOD, GPIOD_LED2);
        chEvtWaitAny((eventmask_t)1);
    (void)extp;
    (void)channel;
    chSysLockFromIsr();
    chEvtSignalFlagsI(tpThread, (eventmask_t)1);
    chSysUnlockFromIsr()
When I compile, load and run, the same behaviour appears again: Nothing works, It hangs as before I even get to the change to calibrate the screen. I get into _unhandled_exception.
Any ideas?
I don't think that it is some issue with my touchpad code, because it works great without the IRQ stuff.
