irq_vector_t and vectors_t in v18.2.n
josesimoes
Has thanked: 43 times
Been thanked: 23 times
Post by josesimoes »
What is replacing irq_vector_t and vectors_t in v18.2.n?
I'm using those to access the vector table and check for a valid address. In this new version the vectors are now in an assembly file...
If the above don't exist anymore, is there a recommendation on how to replace them and achieve the same purpose?
Thanks!
Re: irq_vector_t and vectors_t in v18.2.n
You could take the header from the previous version and use the definitions, the table layout is exactly the same, alternatively you can use offsets using the VTOR registers as a base.
