How to work with virtual timers?
francie84
Post by francie84 »
i'm using the last available ChibiStudio release (With ChibiOS eclipse tools 2.5.0) and a STM32F401RE Nucleo board.
I'm working on the following code:
#include "ch.h"
#include "chprintf.h"
BaseSequentialStream* chp = (BaseSequentialStream*) &SD2;
static virtual_timer_t led_vt;
*  timer callback.
static void cb(void *arg) {
chprintf(chp,"Hi!\r\n");
chSysLockFromISR();
chVTSetI(&led_vt, MS2ST(500), cb, NULL);
chSysUnlockFromISR();
* Application main function.
int main(void) {
* System initializations.
* - Kernel initialization, the main() function becomes a thread * RTOS is active. Interrupts are enabled on chSysInit() exit.
* Activates the serial driver 2 using the driver default configuration.
sdStart(&SD2, NULL);
/* timer initialization.*/
chVTObjectInit(&led_vt);
/* Starting .*/
chVTSet(&led_vt, MS2ST(500), cb, NULL);
That's supposed to display " hi " every 500ms, but it's not working, i can't see anything on my terminal.
Do i have to enable any particular driver or something for Virtual Timers?
Re: How to work with virtual timers?
Enable state checker and assertions, those would reveal that you cannot call blocking functions from ISR context (writing on a stream).
francie84
Post by francie84 »
Giovanni wrote:Hi,
Thank you Giovanni, can you tell me a bit more?
I need that timer to set a float variabile when the callback occours, and i used that chprintf to prove the timer was working fine.. i also read that way is the good one to re-set the timer (i mean using chSysLock and chSysUnlock in the function).. where am i wrong?
Writing is a blocking operation, you cannot block in an ISR, there is not much else to say.
What you can do is to wakeup a thread that then does the writing.
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Post by RoccoMarco »
I can see a couple of problems problems.
  • halInit is missing
  • there is not the loop inside the main
