STM32F051-DISCOVERY Demo Error Flashing
aimatt
Post by aimatt »
Here's the output after I successfully compile the ARMCM0-STM32F051-DISCOVERY demo with YAGARTO and try to load it on the device:
(gdb) load ~/Dropbox/Projects/OpenSource/ChibiOS/demos/ARMCM0-STM32F051-DISCOVERY/build/ch.elf
Loading section startup, size 0xc0 lma 0x8000000
Loading section .text, size 0x67d8 lma 0x80000c0
Loading section .data, size 0xb0 lma 0x8006898
Error finishing flash operation
(gdb) continue
Continuing.
Cannot access memory at address 0xffffffff
The blink example that comes with the stlink source works fine.
I do see the COM red and green LEDs blinking opposite each other. Is this what the demo is supposed to do? I'm thinking maybe it did upload but I was expecting the user LEDs to blink.
Re: STM32F051-DISCOVERY Demo Error Flashing
The two user leds should both blink. It could be a loading problem, what GDB server are you using? version?
I use the server from the Atollic toochain 3.1.0.
aimatt
Post by aimatt »
I am using the stlink OS X port from https://github.com/texane/stlink. Pulled yesterday.
I just re-tested the demo from the current trunk and it worked as expected, I think it could be something about the GDB server, could you try using the lates ST Visual Programmer (I assume they updated it for the F0).
aimatt
Post by aimatt »
I flashed it with the ST-Link GUI and it worked! I wanted to stay native OS X, but I can live with compiling on OS X and flashing with the Windows virtual machine. At least I get to use my favorite text editor.
Thanks a lot for the quick response. I'm looking forward to doing fun things with ChibiOS.
You could report the problem to the GDB server author, probably there is a simple fix.
aimatt
Post by aimatt »
I submitted an issue on their Github page
