Improvement on new interval system Topic is solved
Thargon
Has thanked: 15 times
Been thanked: 24 times
Post by Thargon »
I just had a closer look at the new interval system of the 18.2 release. I can not see the reason, why CH_CFG_TIME_TYPES_SIZE is limited to 16 and 32 bit size, though. Of course, there is the risk of overflows in the conversion functions so that 'time_conv_t' has always double the size than the other types, but is is implemented in a very pessimistic way. I would like to see the possibility to set CH_CFG_TIME_TYPES_SIZE to 64, as there is plenty of headroom (depending on other settings) before overflows may occur.
The worst case appears to be in the US2I conversion functions:
#define TIME_US2I(usecs)                                                    \
  ((sysinterval_t)((((time_conv_t)(usecs) *                                 \
                     (time_conv_t)CH_CFG_ST_FREQUENCY) +                    \
                    (time_conv_t)999999) / (time_conv_t)1000000))
The critical section here is
(((time_conv_t)(usecs) * (time_conv_t)CH_CFG_ST_FREQUENCY) + (time_conv_t)999999)
as the result of this calculation must fit into 'time_conv_t'.
Consequently, the maximum value of 'usecs' can be calculated as
usecs <= ((time_conv_t)-1 - 999999) / (time_conv_t)CH_CFG_ST_FREQUENCY
Now let's assume 64 bit width of 'time_conv_t' and a very high setting of CH_CFG_ST_FREQUENCY:
chconf.h
// 1us resolution
#define CH_CFG_ST_FREQUENCY 1000000
This results in
       = (2^64-1 - 999999) / 1000000
       = 1.84E13
As you can see the result is much bigger than 2^32 (4.29E9) and would be even higher for smaller CH_CFG_ST_FREQUENCY.
I would propose a solution where CH_CFG_TIME_TYPES_SIZE can be set to 64, but the secure time conversion functions check the argument for this maximum value, i.e.
chDbgAssert(usecs <= ((time_conv_t)-1 - (time_conv_t)999999) / (time_conv_t)CH_CFG_ST_FREQUENCY);
Best regards,
Thomas
Re: Improvement on new interval system
The time_conv_t type is meant to avoid those overflows this is why uint64_t is not supported for time, it would require a 128bits type for time_conv_t.
Thargon
Post by Thargon »
in general you are completely right and I support your opinion. But in practice we are on a scale where overflows will only occur in rare cases as I mentioned at the end of my post. As I showed, given a 64 bit wide time_conv_t and a CH_CFG_ST_FREQUENCY of 1 MHz, you can still safely calculate timeframes of up to 213.5 days! If you reduce the system tick frequency, this number increases, of course.
However, since the sysinterval_t can not be wider than 32 bit, the maximum timeframe that can be represented (given the 1 MHz frequency) is merely 0.05 days (71.4 minutes), which is quite a waste, imo.
In order to prevent overflows as you mentioned, I already proposed a solution in my original post, by adding an additional assert to the convertion functions. You could just check if the width of sysinterval_t is greater or equal to the width of time_conv_t to enable this assert.
There is nothing that will make ChibiOS unsafe or whatsoever, but this feature would further increase system flexibility.
Thomas
